Thanks ! It's in normal limit.
I finally found why the third fuselage flies so well, thanks to the new device ! CG = 92 mm ! ( in the manufacturer's manual it is recommended CG = 87 - 90 mm ). |
Thanks too, Jean Luc, to watch my posts.
And a little demo. Second flight of "Introduction F5J" with third fuselage, was launced at 35.9 m, and glide for 91.6 seconds. Resulting sink rate 0.3919 m/s. Second day, I have a flight of 12.38 minutes, launced at 146 m. Because I setup CG on the fly field, balancing glider in the hand, and feel that the CG is far rear from previous ones, and feel good seeing how good fly, Always wanted to check out CG. But it took some time before I managed to build a new one CG scale. Now is very clear: CG = 92 mm. |
excellent results ...
based on your tests i have noted to rear my CG and make tests during next flights at spring. With my multiplex balance i am used to verify my CG and i will make some additional marks for test in the model. I use a spirit level when using the multiplex balance. Eventhought the precision is certainly less than your machine, what counts in fact is measure consistency / repetitiveness and deviation of CG, step by step. Your tests are key information, thanks |
The fourth fuselage (14)
I received carbon fiber tube: 1m, 26 grams. I think to make a fuselage mix of balsa, plywood and carbon tube. Next year
.I have checked weight before covering: 101 grams. Cover with oralight transparent white (10). |
The fourth fuselage (15)
Little operations
. I forget to make an additional hole for cooling. I forget to check if wing fit on this fuselage. It would have been good to do them before the covering. Now all that is do. I checked if fuselage is right with help of carbon tube . Ready to glue direction.
A new fuselage with carbon tube
I have broken two fuselage until now
. I think that is time to design my own fuselage for Introduction F5J. In general will be same, but tail will be a carbon tube.After some days of thinking how to do that, today I make first piece. Will be a long way, because all pieces will be done manually .
excellent research on carbon tube integration
Regarding wood working may I suggest you 2 tools that are wonderful and extremely useful ? 1/ is a "bocfil " (copying saw ) and 2/ is a "jeweler cheville" the bocfill is so helpful to saw wood in very direction the "cheville" is extremely handy to cut wood, i did mine some years ago, it is a mythic jeweler tool that you can manufacture easily and will last for life if you are interested i can send you a photo of mine bonnes fetes ... |
But I prefer my power tools when possible. Here it was about copying a part very exactly, and then I prefer to do it manually with hand tools, especially for the prototype. |
A new fuselage with carbon tube (2)
One more piece. For now, I make them from 3 mm abaci. In the end I will make them from 3 mm plywood. These two pieces are essential for good alignment of the carbon tube.
A new fuselage with carbon tube (4)
A challenge is to make nose block R22.
| Similar Threads | |||||
| Category | Thread | Thread Starter | Forum | Replies | Last Post |
| Discussion | Introduction F5J build | kurtataltos | Electric Sailplanes | 931 | May 27, 2025 02:35 AM |
| New Product | Inside F5J -- Excellent F5J/ALES 6-servo wing kit | ripacheco | Electric Competition Soaring-F5J, eF3K, F5K, ALES | 2498 | Mar 29, 2025 03:51 PM |
| Discussion | Anybody else build an Introduction F5J | fcbflyer | Electric Competition Soaring-F5J, eF3K, F5K, ALES | 246 | Jun 30, 2020 10:34 AM |
| Discussion | Introduction F5J ALES Competing | tr41nwr3k | Electric Competition Soaring-F5J, eF3K, F5K, ALES | 8 | Apr 23, 2020 08:44 AM |
| Discussion | Introduction F5J Spoiler location/size | kurtataltos | Electric Sailplanes | 7 | Jan 29, 2017 05:17 AM |
