This thread is privately moderated by popad, who may elect to delete unwanted replies.
Mar 20, 2022, 05:54 AM
Thanks Popad for your drawing, it is clear :-)
well .... you are very close to maiden, hope you will report and why not post a video ...
Mar 20, 2022, 06:04 AM
RC Pilot & Builder
popad's Avatar
Good ! Thanks.
I waiting some materials to finish all. I hope to receive these Thursday.
I will try to prepare everything by then. Station settings, servo adjustment ... of course will be pictures of these things.
Mar 21, 2022, 04:14 AM
RC Pilot & Builder
popad's Avatar
I fixed ESC, UBEC, receiver in their place, so that I have room for the battery and can move it to fine tune the CG.
I prepared the second batch of batteries. I have changed connector XT60 with T-Deans.
Mar 21, 2022, 09:38 AM
RC Pilot & Builder
popad's Avatar
I copied the first model in the station and renamed it. I connected the receiver to the station. I turned everything off and restarted the station, then the receiver. Now all servos should be zero. I attached the servo levers to the appropriate position. Then I checked to see if everything was working properly. Less the engine. We'll check on him later. This stage ends here.
Test Introduction F5J setup OpenTx (0 min 47 sec)
Mar 22, 2022, 02:44 AM
fine - Thanks ...
Mar 22, 2022, 04:52 AM
RC Pilot & Builder
popad's Avatar
Today mount servos for flaps/breaks in the wing. Mount control levers for rudder, elevator and breaks. Not yet glue .
Mar 22, 2022, 01:28 PM
RC Pilot & Builder
popad's Avatar
Thanks to RCGroups !
Thanks to RCGroups for that ...
Mar 22, 2022, 05:41 PM
thanking you too Popad .... your photos and report help a lot
awaiting for your maiden flight :-)
Mar 25, 2022, 11:00 AM
RC Pilot & Builder
popad's Avatar
Little optimization of wiring of second Introduction F5J. Some change on first one. They are twins. All must be same and interchangeable.
Next steps:
Bend all end rods to 90 degree, and cut coresponding.
Check and set CG for both gliders.
Mar 27, 2022, 06:52 AM
RC Pilot & Builder
popad's Avatar
F79
I had a dilemma. I searched for F79 in electronic documents. Today I looked in the printed manual I received with the kit and finally found it. In general, I used the downloaded electronic manual. My concern was that this F79 screw should have been fitted before covering. But no, it's step 67, near the final .
Warning: There are some differences between the printed manual and the electronic versions available.
I did a test with Micro E / Z link from DU-BRO 0.032 "(0.81 mm), which I only received. It was worth the wait. I will use them.
And I prepared the fuselage covers for ALTIS Nano and GliderKeeper. The difference in size between the two required an adaptation. It's solved now.
Small steps! Now I'm ready to start completing the two gliders next week ...
Mar 28, 2022, 03:58 AM
Thanks Popad, i was just looking for the Micro E / Z link's
The ALTIS Nano and GliderKeeper sound to be very interesting ...
Mar 29, 2022, 09:33 AM
RC Pilot & Builder
popad's Avatar
Simple operations:
01. Setting the rod forks in the center.
02. Lubricate the rods with silicone oil.
03. Mounting the rods.
04. Elevator mounting.
05. Fixing control rods with flag.
06. ON station, ON receiver, center for rudder and elevator.
07. 90 degree bending rods for rudder and elevator.
08. Mount the wing.
09. Fixing flaps next to the wing segments.
10. Setting the forks in the center.
11. ON station, ON receiver, normal for flaps.
12. Fixing control rods with flag in the servo wing levers.
13. Bending 90 degree flap rods.
E/Z link don't fit.
Now only a CG check, before go to flight field
Mar 29, 2022, 01:56 PM
RC Pilot & Builder
popad's Avatar
The last piece ... prop & spiner: 10" X 6" or 11" X 6".
Mar 30, 2022, 01:03 AM
Bonjour Popad, nice & instructive pics, thanks for sharing. All this represent a lot of work ...
Mar 30, 2022, 07:45 AM
Hector Parra's Avatar
Very nice build, and very interesting plane.
Is this kit available in the US /Canada?
Discussion Introduction F5J build kurtataltos Electric Sailplanes 931 May 27, 2025 02:35 AM
New Product Inside F5J -- Excellent F5J/ALES 6-servo wing kit ripacheco Electric Competition Soaring-F5J, eF3K, F5K, ALES 2498 Mar 29, 2025 03:51 PM
Discussion Anybody else build an Introduction F5J fcbflyer Electric Competition Soaring-F5J, eF3K, F5K, ALES 246 Jun 30, 2020 10:34 AM
Discussion Introduction F5J ALES Competing tr41nwr3k Electric Competition Soaring-F5J, eF3K, F5K, ALES 8 Apr 23, 2020 08:44 AM
Discussion Introduction F5J Spoiler location/size kurtataltos Electric Sailplanes 7 Jan 29, 2017 05:17 AM
