Sep 09, 2021, 04:15 AM
A geriatric flier
Help!
Pilot 67" Slick
I have jst taken delivery of the 67" Slick and have a problem, or think I have a problem. The stab does not fully engage into the slot in the fuse. I could go 3mm further forward to fully engage in the slot. As it is the stab has 2 deg positive incidence compared with the wing.
Sep 09, 2021, 01:27 PM
Chef Pilot: Planes vs Butter
ChinoDiablo's Avatar
If the stab is absolutely, positively as far in as it will go, then it looks like you'll need to do some carving to even things out. Looks like some wood is blocking where the covering is open to show where it should go.
The gap in the covering underneath also looks like where it lines up.
There should be 0 degrees of incidence.
So either the frame is wonky or the covering.
My suggestion it to take out the stab and do some line ups with a ruler from the POV of the opening to the wing and then with the covering to the wing to figure out which, if either, is right.
Sep 09, 2021, 03:15 PM
Ronaldo Nogueira
ronaldopn's Avatar
Inspect carefully inside and check if there is no excess glue on the corners or something else which could be preventing the stab from sliding until its stop.
I have a Slick 74" which has the same type of fitting and it installed perfectly.
Ronaldo
Sep 09, 2021, 10:35 PM
A geriatric flier
Thanks guys. I think the wing incidence should be zero zero. I asked the question here because I had a Pilot Edge 540 and I assembled it and didn't check the wing/stab incidence during the assembly. The stab on that had about one and half degree positive angle compared to the wing. It flew like a dog and whilst I played about with it trying to improve it, it ended up in the bin. The problem was taken up with Pilot and they were not interested. Likewise I have taken the Slick problem up with the supplier and they are not interested, neither would they tell me what the wing incidence should be.
Sep 25, 2021, 07:48 AM
The stab is +2 compared to what? Don't always trust the canopy base. It's almost never a zero. I would try to get the stab and motor to zero while the wing is +.5
That would be my starting point if you don't just try what's built in first.
Oct 08, 2021, 05:27 AM
A geriatric flier
As you are probably aware there are pins in the rear and front of the wing roots which locate the wing into the fuse. Those pins are on the centre line of the wing. I put a rod through the holes in the fuse and zero the level of the fuse on those rods. The 2 deg+ is compared to that.
Discussion 67 Slick 580/SBach 342 20cc, Phoenix Models/Tower Hobbies ChinoDiablo 3D Flying 251 Oct 19, 2021 03:30 PM
New Product 67"(22%) EXTRA 330SC Pilot-rc hot wings 3D Flying 125 May 31, 2020 11:56 AM
Discussion 67 Inch Edge 540 V3 Green Print ARF by Pilot RC jobinseattle 3D Flying 4 Feb 09, 2019 11:44 AM
New Product Pilot-RC 67" EXTRA330SC pilot-rc 3D Flying 8 Jul 12, 2017 05:26 AM
Cool 12 Year Old Pilot - 67 Hours - Instructor Wants To Sign Him Off Sladex General Aviation 14 Apr 23, 2013 10:03 AM
