Sep 06, 2021, 02:48 AM
change fans Anycubic Viper
Are there people who have change the originel fans to silent fans on their Anycubic Viper.
Sep 09, 2021, 03:22 PM
Newbie WW1 Flying Ace
tww1fa's Avatar
When it comes to fans, the adage "you don't get something for nothing" applies. There are several possible causes for fan noise - one is bearings and the motor portion, the other is airflow. Changing fans to reduce bearing/motor noise is fine, as long as the new fan has the same or better airflow characteristics.
If the majority of your noise is due to the airflow, be very careful about replacing the fan. If you replace the hot end cooling fan with one that doesn't perform as well you'll be letting yourself in to a world of filament jams. Replacing the part cooling fan with a less-performing one can lead to worse overhangs and generally inferior print quality.
Build Log gift for fans of a pane design viper jet ahmedooh10 Scratchbuilt EDFs 2 Feb 21, 2024 12:39 PM
Help! Graupner Viper Jet 1400 : Securing the EDF Fan ??? hexaflyer Electric Ducted Fan Jet Talk 4 Feb 03, 2017 10:08 AM
HP DL580 G5 change fan type with another PWM 4pin. pietrafesa Batteries and Chargers 0 Feb 25, 2016 05:52 AM
Discussion New Change Sun Viper 90mm.......one piece, 11 blade rotor Knife Liddle Electric Ducted Fan Jet Talk 1 Feb 05, 2013 01:13 AM
