Suggested channels for Hitec Optic 6 TX and a 4 channel RX
I'm looking to setup a discus launch glider with a 4 channel receiver. What is the preferred channel ordering with a hitec optic 6 transmitter? The 4 channels will be Elevator, Rudder and left & right flaperon. Looks like I'll need to setup elevator/flap mixing and rudder aileron mixing. Thanks for the help.
Geoff |
On HiTec radios, channels 6 and 7 are for flaps. It sounds like you have ailerons, which you want to use as flaperons for landing. For that, you will set up your ailerons on channels 1 and 5, and then use the crow mix. You still need a five or six channel rx.
Just to clear the waters a little: I have an Optic 6.
To use flapperons on a DLG you can use either channels 1 & 5 or 1 & 6. If you use 1 & 5, you need to activate aileron differential, then you can use the camber setting for a switched preset and the crow setting for variable camber. You can also have the crow setting controlled by the throttle stick. If you use 1 & 6, you need to activate flapperon, then you use the right slider to control camber and the land function for a preset. I would personally recommend using channels 1 & 5, meaning you only need a 5-channel receiver (channels 1, 2, 4, & 5). The reason for this is that variable camber on the throttle stick would be much more convenient than the right slider. Also, camber and crow both include elevator compensation, while normal "flapperon" travel does not. I hope this helps. God bless! Wayne J. |
Thanks for the help guys.
Hi,
This is a typical problem with most transmitters that have fixed channel assignment (not so with Multiplex EVO 9 & 12, MC3010,3030 & 4000). But in your case, as channel 3 is not in use, could you not use a free programmable mixer (if any) to mix channel 3 as slave with channel 5 as master? Any input on channel 5 will then activate channel 3. Up to you to check for the right direction of mixing. If this works, perhaps trims on your ailerons is not affecting the aileron-servo that would be connected to channel 3. Up to you to check this also. Hopefully it works, that would save you some $$$. Please revert if it works. Olivier |
Optic 6:
1. Any PMX-ed slave channel does not respond to the trim of the master channel. 2. There's no way to disable the master control (stick, switch, widget) for the slaved in #1 channel. In valkyrie83's case - if channel 3 is slaved to channel 5 (or 6 if FLPN is used instead of ADIF): 1. The aileron trim will not affect the aileron servo connected to ch. 3. 2. The throttle stick will move the aileron servo connected to ch. 3. |
Thread Tools | |
Similar Threads | |||||
Sold | Hitec Optic 6 TX Digital Proportional FM Radio - 6-CH FOR SALE $110 OBO | onelightfound | Aircraft - General - Radio Equipment (FS/W) | 1 | Apr 24, 2007 02:03 AM |
Question | Hitec 5 channel single conversion RX-Hitec optic 6 TX | redtail | Radios | 6 | Aug 29, 2006 01:43 PM |
WTB: Hitec Optic 6 TX Charger | DrunkFlyer | Aircraft - General - Radio Equipment (FS/W) | 2 | May 18, 2005 04:27 PM | |
FS Hitec Optic 6 with Spectra Module and RX and Servos | johnreilly | Aircraft - General - Radio Equipment (FS/W) | 6 | Apr 24, 2005 10:53 PM | |
Hitec Optic 6 Tx w/ Spectra for $139! | thomer | Vendor Talk | 8 | Apr 05, 2005 10:43 PM |
