BetaFPV Beta95X V3 Whoop Quadcopter
V3 Whoop Quadcopter(HD Digital VTX) totally reinvents the traditional cinematic drones!
Beta95X V3 Whoop
Coming with brand new pusher design, equipped with Caddx Nebula Pro HD System, and supports to combine with the SMO 4K action camera, Beta95X. It gives pilots an amazing HD flight experience, bringing pilots to a fairly clear image of every highlight moment!
  • Beta95X V3 is perfectly suitable for the SMO 4K action camera. With a built-in camera mount and a power cable, it's very convenient for out-of-the-box installation and power input for the camera. Combining with SMO 4K, pilots can get a stable & high-quality video while in FPV flight.
  • Equipped with the nebula Nano HD System, perfectly supports the DJI HD system. This lightweight kit provides a stable FPV picture and long transmission distance, greatly bring you a unique flight experience.
  • Adopts a brand-new innovative pusher frame design, Beta95X V3 is more durable and easier for installation than Beta95X V2. The frame also comes with an EVA foam cushioning design to give you more safety flying.
  • Equipped with F4 AIO 20A Toothpick FC V4, 1106 3800KV motor, and D63 5-blade props, this highly efficient power system keeps Beta95X V3 more powerful and less noise in flight. For the battery, we highly recommend you using the BETAFPV 450mAh 4S battery to get the best flying experience.
  • Centering the drone's gravity by reversed-motor design and top battery place makes the drone more maneuverable to achieve all FPV freestyle tricks such as diving.
  • Further improves the shock mitigation system to eliminate the shake of the camera, Beta95X V3 HD Digital VTX will make the camera more stable on the flight, which ensures pilots can capture all the beautiful moments of flight with the stabilized and clear video.
Specification
  • Item: Beta95X V3 (HD Digital VTX)
  • Weight: 117.3g (without battery)
  • Wheelbase: 95mm
  • FC: F4 AIO 20A Toothpick Brushless FC V4
  • Frame: Beta95X V3 Frame Kit
  • Motors: 1106 3800KV Brushless Motor
  • Props: Gemfan D63 5-Blades Props
  • Receiver Option: Frsky FCC/Frsky LBT/TBS/PNP
  • FPV Camera Degree: 25- 45
  • HD digital camera & VTX: Caddx Nebula Pro HD System
  • Camera Mount: SMO 4K camera Mount
  • HD Camera Mount Degree: 5- 45
  • Antenna: Air 5.8GHz Antenna (LHCP)
  • Battery: 450mAh 4S battery(Not including)
  • Charge Connector: XT30
  • Flight time: About 3.5 min flight with 450mAh 4S battery
Motor & Props
Gemfan D63 5-Blades Props is designed for the inverted installation, and it brings pilots a smooth flight! Meanwhile, compared with D63 3-blades propellers, D63 5-blade props are more durable and more powerful, offers pilots a high-efficiency flight experience. Equipped with the 1106 3800KV Brushless Motor, it brings a stronger power and lower noise, which will give pilots an unprecedented flying experience.
FC & ESC
Beta95X V3 series whoop drone is equipped with the new released F4 20A AIO toothpick brushless FC, it extremely reduces the weight while improving the ability of the ESC to continuous current 20A, and brings pilots more power to fly the Beta95X V3 quad! Meanwhile, the new 20A FC V4 adds 2 pin connector ports for DJI Digital VTX and Rx, just plug & play, less solder work needed, super easy to install.
Beta95X V3 Pusher Frame
A newly designed pusher whoop frame - Beta95X V3 Frame is made of high-quality PA12 material, which can dampen noise and vibrations and have high abrasion resistance, bringing the drone a more durable flight and no fear of damage. Meanwhile, it also comes with an EVA foam cushioning design to give you more safety flying. The pusher style puts all the cameras and batteries on the top of the platform, makes the center of gravity is right in the middle of the drone, brings the best fly operability.
Learn More
Head to Hobbymate for pricing and more info!
Aug 03, 2021, 06:26 AM
luschengerman
Hallo!
the cameramount is my idea!
https://www.thingiverse.com/thing:4548605
Help! BetaFPV Beta95X Pouncer Micro Multirotor Drones 6 Jul 08, 2020 06:30 PM
Discussion BetaFPV Beta95X with DJI HD DreadRedbeard Micro Multirotor Drones 7 Mar 29, 2020 10:55 PM
