Aug 02, 2021, 06:09 AM
Help!
Pitch Oscilation bei high throttle - HGLRC Sector 5 V3
Hi!
I desperately need help with my new 5" quad "HGLRC Sector 5 V3".
The quad starts oscillating around the pitch axis at medium to high throttle.
It's a 4-6s quad and it happens only with 6s packs installed.
Here is a video showing how it sounds and looks like:
https://cloud.kranzhoff.de/s/XLfbZTCc1q7wDUF
Additional information I can provide:
- I already own multiple 5" quads from different brands that do not suffer from this issue
- the quad is brand new without any damage
- the issue appears with 6s packs only, with 4s it flies extremely smooth even at highest throttle
- all screws and the props have been checked multiple times
- I already checked with different prop sets and prop brands
- the frame is intact, no cracks
- the soldering points are all fine
- I tried adjusting filter and PID values to no avail. Only increasing TPA to 0.85 at 1000 slightly reduces the issue, but it's not gone at all
After searching for the cause for several hours I assume this is a hardware issue.
But where should I start searching? FC/Gyro, ESC or motors?
Did anyone have a similar issue or might point me into the right direction?
Components:
- FC: Zeus F722
- ESC: Zeus 48A BL_S 3-6S 4in1 ESC
- Motors: AEOLUS 2306.5 1900KV
- Props: EthixS5
BlackBox Log (16 Mb):
https://cloud.kranzhoff.de/s/PPufoCg28ZiqJkF
GERMAN version below:
Hallo zusammen!
Ich brauche einen Rat bei meinem neuen 5" Quad "HGLRC Sector 5 v3".
Bei Throttle > 50% beginnt der Quad stark auf der pitch-Achse zu vibrieren, besonders wenn Throttle schnell erhöht wird.
In diesem Video sieht und hört man das Problem gut, denke ich:
In den blackbox Daten sieht man es auch recht deutlich (siehe Anhang).
Folgende Infos kann ich noch geben:
- ich habe bereits mehrere 5" Quads anderer Hersteller, die dieses Problem nicht haben
- Quad ist neu und ohne Beschädigungen durch Crashes
- das Problem tritt nur bei 6s Akkus auf, bei 4s überhaupt nicht (ist eine 4-6s Version)
- alle Schrauben sind fest, auch die der Propeller
- Rahmen ist intakt und ohne Risse, Lötpunkte ebenfalls
- habe bereits verschiedene Propeller-Sets und Marken probiert
- über die PID und Filtereinstellungen habe ich das Problem nicht gelöst bekommen, extreme TPA Werte (0,85 ab 1000) reduzieren es aber leicht
Ich gehe mittlerweile davon aus, dass ein Hardwaredefekt ab Werk vorliegt.
Aber wo fange ich an zu suchen? FC/Gyro, ESC oder Motoren?
Hat jemand vielleicht einen Tipp für mich oder schon mal ein ähnliches Problem gehabt?
Komponenten:
- FC: Zeus F722
- Motoren: AEOLUS 2306.5 1900KV
- Props: EthixS5
Discussion HGLRC sector 5 v3 HD 6S - Beefy Freestyler DutchRC Multirotor Drone Talk 2 Nov 02, 2020 01:37 PM
New Product HGLRC Sector Freestyle 5/6/7 Inch 226/260/296mm Wheelbase 5mm Arm 3K Carbon Fiber Merch Banggood.com 0 Aug 14, 2019 10:57 PM
Help! Oscillation at High Throttle. Tonxboy Multirotor Drone Electronics 2 Apr 26, 2017 07:18 AM
