This thread is privately moderated by Eric Zhu, who may elect to delete unwanted replies.
Jul 30, 2021, 11:04 PM
New Product
New Arrival on Amazon! AGFRC 78KG Monster Torque IP67 Waterproof 1/5 Scale Servo
AGFRC A280BHMW 78KG High Torque IP67 Waterproof Full Metal Gear Brushless Digital 1/5 Scales RC Servo for 1/5 RC Models, Control Angle 180°
A280BHMW is a 2s version 5th scale servo. It combines long-life brushless motor with monster torque design takes the driving experience of large model enthusiasts to a new level. It is ideal for 1/5 Monster Truck, Buggy, Crawler, Large Airplanes, Robot Arm, etc. Whether you are traversing the jungle or climbing over sand dunes, 5 ball bearings and strengthening gear structure improve the crashworthiness and life of the servo.
Description:
When you cross the mountains and pass the charming stream, fully magnetic waterproof IP67 grade can let your model play in humid environment or rainy day. This A280BHMW is suitable for most 1/5 scale models, which require to use with 2s lipo battery. 78KG superb torque and 0.082Sec lightning fast speed, believe that your model can give full play to its handsome charm. Ultra light unique design with heat sink machining for medium and bottom case, so that the internal structure of the servo can absorb heat and smooth operation. Of course! In this era of rapid development, free choice is also a kind of happiness! So how could we do without the programmable function? It is fully upgrade to be bluetooth APP programmable in the near future. Please don't hesitate to add a reliable new partner to your model!
Description:
Features
  • Heat Sink Aluminum Case
  • Extremely Strong Steel Gears
  • Super Reliable Five Ball Bearing
  • 2S Lipo High Voltage Compatible
  • Associated 15T Aluminum Servo Horns
  • Magnetic Sensor Waterproof IP67
Description:
Stall Torque
  • 48.0 kg-cm (667 oz-in)  @ 4.8V
  • 58.0 kg-cm (806 oz-in)  @ 6.0V
  • 66.0 kg-cm (917 oz-in)  @ 7.4V
  • 78.0 kg-cm (1084 oz-in)  @ 8.4V
Operating Speed
  • 0.126 sec/ 60° @ 4.8V
  • 0.110 sec/60° @ 6.0V
  • 0.095 sec/60° @ 7.4V
  • 0.082 sec/60° @ 8.4V
Specification
  • Brand: AGFRC
  • Control System: PWM, 1520uS/333hz
  • Operating Voltage: 4.8~8.4V
  • Dead band: 2 uSec
  • Mechanical Angle: No limit
  • Operating Travel: 180°±10°, 500 to 2500 uSec
  • Horn Gear Spline: 15T-φ7.80mm
  • Bearing: Five Ball Bearings
  • Case Material: AL6061T6
  • Size: 65.8*30.0*59.0mm
  • Certification: CE, FCC, RoHs
  • Weight: 284.8g
  • Wire: TYU 300mm/22AWG
This servo is in the new product promotion period, 15 USD coupon off, if you're interesting in this A280BHMW 1/5 scale servo, please search for B098N8D93L on US Amazon or click the link: https://www.amazon.com/AGFRC-78KG-Hi...of+high+Torque
Aug 14, 2021, 02:27 AM
Unboxing video for A280BHMW servo :
Detroit Performance AGFRC Giant 1/5 Scale Brushless Servo (10 min 12 sec)
New Product New Arrival! AGFRC 12V 66KG Monster Torque Programmable IP67 Waterproof Servo Eric Zhu Off-road Cars 1 Jun 04, 2020 04:52 AM
