DW Hobby Savage Bobber 1.0M
The RC version of the Savage Bobber has been designed in the same spirit, that of a FUN plane, amazing and easy to fly.
RC Model of the Savage Bobber
The full-size Bobber is the result of many years of experience building Savages. Robust, easy to handle and maintain, it is beautiful, it is FUN! The Savage Bobber is the plane that makes you daydream! The RC version of the Savage Bobber has been designed in the same spirit, that of a FUN plane, amazing and easy to fly. With its 600g in flight weight, it is probably the lightest RC aircraft in the 1m wingspan category. To achieve this featherlight weight which also allows it to fly extremely slowly, another of the characteristics of this aircraft, its equipment had to be very light. It flies perfectly with a 1300mah 2s battery and its 6 servos weigh only 3.7g. each The controller was also chosen to be very light.
Features:
  • Super Light
  • Super slow flying
  • Big hand-made foam wheels
Technical specifications:
  • Wingspan: 1000mm
  • Length: 700mm
  • Flying weight: about 600g
  • Motor: MM2208 2600KV
  • Prop: 7inch
  • ESC: 20A
  • 6x Servo: 3.7g
Check out the DW Hobby Savage Bobber 1.0M Here
Jul 27, 2021, 05:17 PM
great price, 190€ with all electronics except the battery.
it's not a crap foamy but it's not described in the french site what material is the fuselage made of...
Jul 27, 2021, 06:04 PM
I just said today NO MORE AIRPLANES
That is kinda cool. Fun low and slow stuff....Like it....Rut
Jul 27, 2021, 06:10 PM
Lifetime Member
JohnM's Avatar
Looks great, wish it was smaller. Will be interesting to see more details and test flights.
I wonder what the light weight controller is referring to in the description
"The controller was also chosen to be very light."
Jul 27, 2021, 08:29 PM
Rabid Rabbit
PookaHat's Avatar
Looks a bit large for indoor flight and too light weight for prevailing winds here.
Jul 27, 2021, 08:56 PM
Electronic Speed Controller
it might be one of these https://www.turbines-rc.com/en/30-mo...t%C3%A9_a_-20a
Jul 27, 2021, 09:31 PM
dgarbern's Avatar
Lightest 40" plane? If you have some balsa lying around you could do a bit better:
Pat Tritle build. 60" Cub, 21oz (595gr).
Jul 27, 2021, 10:37 PM
623g ~ 652g http://patscustom-models.com/shortkit1.html
Jul 27, 2021, 10:56 PM
Digital Don's Avatar
I wonder if there will be a U.S. distributor.
The Savage Bobber definitely has that 'cool factor'.
Landing gear seems a bit spindly though especially since it lacks the center suspension components.
Don
Jul 28, 2021, 06:13 AM
Lifetime Member
JohnM's Avatar
Ok, that makes sense. I was thinking flight controller which didn't make sense to me.
Jul 28, 2021, 12:55 PM
"Aircraftus Fragmentum"
kydawg1's Avatar
Sweet bird.
Jul 28, 2021, 01:48 PM
dgarbern's Avatar
This one:
https://www.rcgroups.com/forums/show...5&postcount=24
Jul 29, 2021, 10:30 AM
DFS#000178
Rampage's Avatar
Yeah 600 grams for the size good but not great. You can do better.
My Jr Skylark is only a tiny bit smaller in wingspan and came in at 18 ounces/510g. And it's a twin..
But this does look really good! I was surprised to see it was an ARF. I was already thinking about clearing off the building board for it..
Jul 29, 2021, 03:33 PM
the video description says: Flying Weight: 500-600g
1.0M ARF Balsa Savage Bobber (1 min 1 sec)
Jul 29, 2021, 04:52 PM
DFS#000178
Rampage's Avatar
It says 580-620g right there in the thumbnail That's quite a bit more narrow than 500-600.
Which probably means it's more like 700 in reality. :P
Not a criticism, like I said it's a good weight but it's by no means the "lightest" you could do with that wingspan.
Discussion planeprint.com Zlin Savage Bobber JUSS10B 3D Printed Planes 85 Aug 19, 2021 08:36 PM
Gallery 1/6 Zlin Savage Bobber Bodie38 Scale Kit/Scratch Built 20 Apr 21, 2021 12:21 AM
Discussion "Savage Bobber" BlRDMAN Scratchbuilt Indoor and Micro Models 13 Oct 28, 2020 09:48 PM
Discussion Savage Bobber - 32" wingspan didilic 3D Printed Planes 11 Sep 18, 2020 03:00 PM
Discussion Savage Bobber from www.planeprint.com hannes12345 3D Printed Planes 2 Oct 16, 2019 05:19 AM
