Jul 16, 2005, 03:54 PM
ianm
ianm's Avatar
Problem with tail blade on X400
Hi all,
This evening whilst trimming out my newly built X400 I lost a tail blade
Fortunately I was just hover about half a metre above the ground at the time so although it just spun out of control I was able to drop it to the ground without any other damage
About 10 seconds earlier I was hovering at about 4 metres high and just came down to make some fine adjustments to the rudder trim in head lock mode ( I was very lucky )
My daughter and myself searched the garden for the missing blade so I could examine it to see what had failed but it had vanished !!
The tail blade holder was still intacted complete with fixing screw so I assume the blade must have broken off around the hole ?.
Has anyone else had any problems with the tail blades supplied with the Ark X400 ?
I have borrowed the tail blades off my Zoom and fitted them to the X400 and they are working fine with no further problems so far
Ian
Jul 16, 2005, 05:04 PM
OK Karen
TheX's Avatar
That's a scary situation. Similar to the Shogun tail grip bearings letting go. I've had it happen 5 times with 3 of them ending up in expensive (Shoguns always are) crashes. I use Boca hybrid bearings now. Not a simgle problem since, go figure.
Jul 16, 2005, 05:11 PM
Scarecow
HoverBovver's Avatar
Common problem it seems - X400 white plastic is brittle. Have also heard of paddles, boom brace ends, fins & UC breaking easily.
Most people seem to be replacing tail rotor with T-rex tail-rotor. Also check paddles regularly for cracks.
Jul 16, 2005, 06:04 PM
ianm
ianm's Avatar
Thanks guys for your feedback and I wish I had seen that thread from rchelispot.com before It's maiden flight.
I have since flown out 2 battery packs with the Zoom tail blades fitted although I was a bit scared of flying any more than a few feet above the ground
Now I can see that the problem was crappy plastic blades supplied with the kit and I feel more confident about more serious test flying tomorrow morning.
PS Is there any other common faults I should be aware of before any more major flying ?.
Ian
Jul 17, 2005, 01:11 AM
That tree again!!!!
thanhTran's Avatar
Neat helis fleet.
i have not had problem with the tail blade flying off like that. But I had swashplate went seperate. One time I had a crash and the one of the blade grips (TREX blade grips) was broken. The stock tail is not balance out of the box is what I see.
thanh
Discussion Slight problem with the tail on my Trex 450s mdavenport Mini Helis 11 Aug 08, 2007 12:05 AM
Discussion Problem with HH gyro on Blade CPP bongo264 Micro Helis 2 Apr 26, 2007 07:30 PM
Problem with two digitals on a Y lead?? rorywquin Radios 1 Mar 18, 2005 10:53 AM
I need help with tail blade balancing: T-rex 450 Silverstreak328 Mini Helis 4 Sep 16, 2004 08:21 PM
problem with warrenty work on futaba 6exa jim mathis Electric Plane Talk 5 Jul 08, 2004 02:10 AM
