H-King (PNF) Swiss J-3 Piper Cub EPO 1400mm
The H-King Swiss J-3 Cub is a genuine scale model of a full-size J-3 Cub and is easy to fly by pilots of all abilities including beginners.
This version of the popular Piper J-3 Cub is in a striking new Swiss color scheme which is a must for all scale pilots. This color scheme uses a lot less paint so there is a bit of a saving in weight which further reduces the already low wing loading. The attention to detail makes it an extremely realistic model, and it comes with a nice, generous size 1400mm wingspan. Like all Cub's with its large wingspan, and stable flying characteristics it is very easy to fly, perfect for low-hour pilots and experts alike. The Swiss Cub also has a new all-metal landing gear which is virtually indestructible, this will survive the hardest of landings. Further weight saving has been achieved by the removal of the metal tail bracing wires, these have been replaced with scale-looking, easy to fit, lightweight elasticated white shock chord.
H-King PNF Swiss J-3 Piper Cub EPO 1400mm - Flight Review (19 min 15 sec)
H-King Swiss Cub MAIDEN SHAKEDOWN Flight! HobbyKing 1400mm (6 min 42 sec)
Putting the H-King Cub together is very simple with every component attached by screws, no glue is required except for some recommended reinforcement purposes. The 9g servos come pre-installed as well as the 45A ESC and powerful 3648-700KV brushless motor. The scale detail is exceptional with plastic injection molded parts used extensively throughout including the dummy engine, wing struts, molded glazing, and large “Cub” wheels. Practical features include the linked steerable tailwheel, large magnetic battery hatch, and the construction is from tough, lightweight, and easy to repair EPO foam.
It is a fantastic-looking model and its unique color scheme makes it look impressive in both the air and on the ground. The Swiss Cub is fitted with a very versatile power train, you can fly it on a 2700mAh 3S which will give you long, lazy scale flights, install a 2450mAh 3S LiHv for sport flying (this is our favorite set-up), or step up to a 2200mAh 4S for a Cub that comes alive with plenty of power for some crazy, stunt flying. All this is achieved using the same motor, ESC, and prop, nothing requires changing. When it comes to performance the choice is yours, but be rest assured, whatever power you choose you will be really pleased with the performance of the H-King Swiss J-3 Cub.
H-King Swiss Cub UNBOXING AND BUILD! HobbyKing 1400mm (21 min 42 sec)
Included in the box are an FPV camera mount and a JST ESC to FPV equipment lead. This mount etc coupled with the crystal clear molded windscreen gives you the opportunity to experience HD scale FPV flying from the cockpit for the ultimate FPV experience.
Features:
  • Authentic scale Swiss color scheme
  • Has realistic attention to detail
  • Virtually indestructible metal landing gear
  • Includes FPV mount and crystal clear windscreen for HD scale FPV flying
  • Excellent flying qualities and low-speed handling
  • Lightweight, tough EPO construction
  • Plug N Fly with pre-installed servos, motor, and ESC
Specs:
  • Wingspan: 1400mm (55”)
  • Length: 950mm
  • Flying weight: 1850g~1900g (depending on set-up)
  • Wing loading: 56g/dm˛
  • Propeller: 12x6
  • ESC: 45A
  • Motor: 3648-700KV brushless outrunner
  • Servos: 4 x 9g
Included:
  • 1 x H-King Swiss J-3 Piper Cub complete EPO airframe
  • 1 x 3648-700KV brushless motor (pre-installed)
  • 1 x 45A brushless ESC (pre-installed)
  • 4 x 9g servos (pre-installed)
  • 1 x Complete hardware pack inc wheel
Learn More
For more details and pricing click here.
Jul 16, 2021, 09:01 AM
Tyro of the Hudson
Very nice and tempting. I have a 1.3m cub so I will probably not jump.
It is a blue version of the FMS plane in red?
If HK built the big balsa cub in Army scheme instead of that Navy scheme I might jump. There are other army L4s if I had to.
Jul 22, 2021, 03:43 PM
I review RC Products
GBLynden's Avatar
This is my maiden flight on 3S Power
HobbyKing H-King Swiss J-3 Cub 1400mm RC Plane Maiden Flight On 3S Power (5 min 47 sec)
Jul 30, 2021, 04:23 PM
It is a remake of the original Starmax green and yellow ones made many years ago with improved landing gear a clearer screen for FPV and a repaint
that makes it look like a new airframe.
Jul 30, 2021, 05:18 PM
I should bring all my Cubs to the flying field and compare them when the HK one arrives.
Jul 30, 2021, 05:19 PM
Khellio
khellio's Avatar
khellio
Personally, I won't be buying it.
While it looks nice and flies well, having the hatch underneath these planes means you need to put the plane on it's back in order to use both hands when inserting the battery and doing that on a bench top or other hard surface can cause damage to wing tips and vertical stab.
Jul 30, 2021, 05:21 PM
Khellio
khellio's Avatar
Jul 31, 2021, 12:41 AM
Top feeder is always nicer. Like the E-Flite Clipped Wing Cub!
New Product H-King PNF Swiss J-3 Piper Cub EPO 1400mm PNF Andy852 Electric Plane Talk 44 Aug 01, 2021 08:00 PM
Discussion Hobby King Piper J-3 Cub 1620mm Boogie_ Scale ARF/RTF 17 Jul 22, 2016 11:50 AM
Discussion STARMAX EPO SUPER PIPER J-3 CUB 1400mm w/ Flight VIDEOS!! Tail Wheel Parkflyers 12 Feb 08, 2012 10:27 PM
Build Log STARMAX EPO SUPER PIPER J-3 CUB 1400mm w/ Flight VIDEOS!!!!!!!!!!!!!! SkylineFlyer Parkflyers 239 Mar 06, 2011 12:16 AM
