TBS MAMBO - FPV RC Radio
The TBS Mambo ups the game from the Tango 2. It features a larger screen, traditional form factor with switches and potentiometers, JR module bay, replaceable batteries and trim buttons!
New Radio from TBS
The TBS Mambo ups the game from the Tango 2. It features a larger screen, traditional form factor with switches and potentiometers, JR module bay, replaceable batteries and trim buttons! It looks like a solid choice for FPV drone pilots. You can pre-order it right now for $139.95.
Check out the new TBs Mambo FPV Radio Here
Here's more from TBS on the new radio.
Team BlackSheep has redefined the portable remote control with the TBS Tango 2. Now we're back with one of the most popular requests: a compact full-size remote! The TBS Mambo follows in the footsteps, but focuses on all of the things the Tango 2 tries not to have: a larger screen, traditional form factor with switches and potentiometers, JR module bay, replaceable batteries and trim buttons!
But do not fear: we haven't made a cookie-cutter remote! With the built-in antenna (external antenna available as optional add-on), the 2-position and momentary gamepad buttons, and TBS Tracer built-in, we've accomplished a few "firsts" that put this radio into a class on its own!
The first radio with TBS Tracer built in. And it fits your existing TBS Crossfire module through the JR bay! TBS Tracer is the world's lowest latency radio link, and builds upon the rock-solid reputation of the TBS Crossfire code base. With the continued development and expansion of the TBS ecosystem, pilots will remain on the bleeding edge of capabilities paired with the ease of use and overall robustness that TBS products are known for.
  • 1.6ms end to end latency
  • 250Hz refresh rate
  • Long range capable
  • High telemetry throughput for Mavlink and long range missions
  • TBS Cloud connectivity
Features:
  • TBS Tracer built-in
  • CRSF V3 protocol support for lowest latency and most direct response of any remote control available
  • Range of up to 25km / 15mi
  • Built-in antenna for ultimate ruggedness
  • External antenna available as add-on
  • Full size, ball bearing hall sensor gimbals
  • Configurable resistance and tension
  • Adjustable throttle & pitch throw (+/- 10 degrees)
  • Spare spring set included for lower tension
  • Ergonomic shell design with grippy rubber edges
  • 4x 3-position switches
  • 2x potentiometer with center notch
  • 1x 2-position switches
  • 1x momentary button
  • 4x digital trim buttons
  • Perfectly balanced lanyard mount
  • Up to 12 channels supported
  • Parallel 18650 x 2 (not included!) with USB-C 2A charging (2.5 hours for full charge)
  • Speech audio output with audio jack & haptic vibration alert
  • Open Source remote control operating system (FreedomTX, temporary fork of OpenTX)
  • Rocker dial and 3 button menu for super simple navigation
  • High resolution (128*64) black & white LCD screen w/ backlight
  • 100+ model memory with included SD-card
  • TBS Cloud compatible
Specifications:
  • Weight: 565g
  • Battery: 2 x 18650
  • Audio: 1W speaker & 3.5mm headphone jack
  • Display: 3.5 LCD panel (128 x 64)
  • Antenna: Embedded antenna
  • Switches: 4 x 3pos | 1 x 2pos | 1 x Momentary
  • USB-C Port: Battery charging (5V, 1A), Firmware upgrades & Simulator / HID
Includes:
  • 1 x TBS Mambo remote control
  • 1 x Springs Set (Lower Tension)
  • 2 x Throttle limitation screws (with allen key)
Jul 15, 2021, 08:29 PM
FL, Sanford
Wrecking Ball's Avatar
Looks like Squidward, or mini Squidward.
Jul 15, 2021, 09:33 PM
RCG Admin
Jason Cole's Avatar
lol!
Jul 15, 2021, 09:39 PM
This https://www.rcgroups.com/forums/show...&postcount=101
Jul 16, 2021, 07:42 AM
Very Nice!!….
Jul 16, 2021, 12:28 PM
ReganATX's Avatar
<delete>
Jul 17, 2021, 08:46 AM
FL, Sanford
Originally Posted by Radikal
oh wow, interesting design! I thought it was an edited picture at first
Jul 19, 2021, 11:04 PM
No, it's not edited and it's legal to use in the USA https://fccid.io/2APABCOCKPITSX
Discussion Welcome to TBS Mambo - new built-in Tracer transmitter Frimen Radios 16 Jul 29, 2021 06:13 AM
Discussion Min-e Mambo, an e-conversion, restoration & tribute to a 1963 Sterling Minnie Mambo Ken Myers Glow to Electric Conversions 49 Oct 23, 2018 10:19 AM
Discussion Diatone 2018 GT-M3 Plus 110mm/170mm RC Drone FPV Racing F4 OSD TBS G1 600TVL 20A BobFromMars Banggood.com 1 Mar 06, 2018 08:16 AM
Discussion TBS Disco with TBS 69 FPV Camera Praztek FPV Equipment 3 Jul 09, 2015 02:14 AM
Discussion Anybody fly an ICare-RC Mambo or Whistler? 8thelephant Parkflyers 0 Dec 10, 2009 02:14 PM
