SMC - True Spec DV Extreme 7.4V 5200mAh 135C wired hardcase
A hardcase car battery with power!
True Spec DV Extreme 7.4V-5200mAh-135C pack
This pack is the lowest priced 5200mAh pack on the market using 100% Lithium Cobalt Oxide(LCO) in combination with advanced materials to increase the power/performance. You will not find another pack in this price range with this much power/performance. Packs at a similar price typically use a blend of LCO and LicoMnNio2 which is a cheaper material. This lowers the cost of the packs but also decreases the performance. One way to tell if a pack doesn't use 100% LCO is to check the weight. Packs with 100% LCO will typically have a higher weight.
  • True mAh +/- 5%: 5200mAh
  • Voltage: 7.4V
  • C rate: 135C
  • Power Factor: PF392 For more information click here
  • Size: 25mm x 47mm x 139mm Hardcase
  • Weight: 294gr
  • Wire size: 10AWG
  • Charge rate: 1C to 5C please note that a higher charge rate will put less mAh into the pack and will reduce cycle life
Learn More
For pricing and more info go here.
Jul 07, 2021, 06:12 PM
if SMC make a 6S 5200mA for under $75 it would sell like hot cakes.
Jul 07, 2021, 06:21 PM
FL, Sanford
Wrecking Ball's Avatar
135C? This is maxamps level stuff for quarter of the price.
Jul 07, 2021, 09:06 PM
↓↘→ + (punch)
theKM's Avatar
135C?... kids stuff. at 135C, that's full to flat in 26 seconds. I need packs that are rated for a dead short...
Jul 08, 2021, 03:18 AM
turkeyfeet
pathfinder's Avatar
Dead short?
Latest blog entry: video
Jul 09, 2021, 12:13 PM
FL, Sanford
Can someone test that pack to confirm the specs?
Jul 24, 2021, 06:45 PM
KE Spins make me dizzy.
They've done testing on very similar packs here. https://www.rcgroups.com/forums/show...st-Comparisons
Held up to 3.92v/cell at 100 amps after five seconds, given it's power factor rating.
New Product SMC True Spec Extreme 1400mAh - 45 Amp -14.8V Danny/SMC FPV Racing 3 Feb 11, 2019 08:30 AM
Mini-Review SMC 3S 37A True Spec 1300mAh RC Devotee Multirotor Drone Power Systems 1 Oct 15, 2015 06:17 PM
SMC True Spec Flight Packs Danny/SMC Batteries and Chargers 40 Sep 01, 2014 06:08 AM
New Product SMC True Spec Flight packs. Danny/SMC SMC-Racing.com 5 Jun 13, 2014 08:46 PM
