DSM - Diff Lock Servo Mount for Aftermarket Servos
Designed to work with most popular servos using both single and two screw mounting ears.
Diff Servo Mount from DSM
This servo mount allows you to run aftermarket servos (such as Reef's 99Micro servos) in your Traxxas TRX-4 & TRX-6 trucks.
This Kit Includes:
Diff Lock Servo Mount(1 Piece) Install Notes: You will not be able to reuse the Traxxas servo savers so you will need to make sure to adjust the end points on your radio so you do not damage the lockers or locker cables. Works with the Bowhouse RC low CG battery tray.
If you are using a Y-Harness to put the front and rear diff lock servos on the same channel you will need a servo signal reverser for one of the servos, such as: https://amzn.to/3xcxkrA
Traxxas 2021 Bronco TRX4 - Reefs 99 micro install DSM Offroad (9 min 26 sec)
Learn More
Click here for more info!
New Product 1/10 RC Car LED Light Lamp Set for Benz TRAXXAS TRX-4 G500 Model Merch Banggood.com 0 Sep 10, 2019 09:10 PM
Video Theibault's Vlog 9 Traxxas TRX-4 First Look, May Kwad Box Theibault Rock Crawlers 0 May 20, 2017 08:34 PM
Help! Looking for Robbe Servo Lock 2 - Wing mount servo cans mdennis Sailplane Talk 2 Apr 13, 2011 03:31 PM
