This thread is privately moderated by kopterheld, who may elect to delete unwanted replies.
Jun 17, 2021, 04:05 PM
Mini-Review
Eachine Novice-IV super Long Range RTF Bundle
Eachine Novice-IV a complete, ready-to-fly set with everything included
Code: BGEACHINE10 - https://www.banggood.com/custlink/KGDRoSVDVq
Novice-IV is a ready-made flight set with 4 inch GPS Quad, Radiomaster TX12 transmitter, EV800DM FPV goggles and batteries. F4 FC 25a ESC's, 1404 KV2750 motors, Caddx Baby Ratel2, 25-400mW VTX, active buzzer, GPS. Very good range with over 1000 meters.
My video with EN subtitles
Eachine Novice-IV super Long Range RTF Bundle (16 min 39 sec)
With GoPro 8 Lite less 250g
127g only the drone
218g with the 1100mAh Lipo for 14 minutes fly time
Eachine-Novice-IV Spare Parts
https://www.banggood.com/custlink/vvDdjA1bSi
Radiomaster TX12 -
Radiomaster TX12 beste Einsteiger Funke und preiswert (4 min 6 sec)
TX12 setup with audio -
Radiomaster TX12 Model einrichten und binden mit FrSky D8 Whoop (5 min 35 sec)
TX12 German menus -
OpenTX 2.3.11 mit deutschen Menüs auf Radiomaster TX12 (4 min 1 sec)
RadioMaster TX12
Hobbyking EU warehouse - http://bit.ly/HKTX12
BG Code: BG3DAB26 - https://www.banggood.com/custlink/vKvyHjpyro
Eachine EV800DM FPV goggles
BG Code: BGDAVIS - https://www.banggood.com/custlink/DGKD6YMk9K
EV800DM 3x Optical Lens
BG Code: BGDAVIS - https://www.banggood.com/custlink/3mDmgg6CUV
2021-06-18 My Eachine Novice-IV DIFF with aktive GPS RESCUE function
# Betaflight / STM32F405 (S405) 4.2.4 Oct 20 2020
batch start
defaults nosave
board_name BETAFLIGHTF4
manufacturer_id FPVM
mcu_id 0023003e5853501620383658
signature
resource BEEPER 1 B04
resource MOTOR 1 C09
resource MOTOR 2 C08
resource MOTOR 3 B00
resource MOTOR 4 B01
resource MOTOR 5 B06
resource PPM 1 B08
resource PWM 1 B08
resource LED_STRIP 1 B06
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 A02
resource SERIAL_TX 3 B10
resource SERIAL_TX 6 C06
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 A03
resource SERIAL_RX 3 B11
resource SERIAL_RX 6 C07
resource INVERTER 2 C13
resource I2C_SCL 2 B10
resource I2C_SDA 2 B11
resource LED 1 B05
resource SPI_SCK 1 A05
resource SPI_SCK 2 B13
resource SPI_SCK 3 C10
resource SPI_MISO 1 A06
resource SPI_MISO 2 B14
resource SPI_MISO 3 C11
resource SPI_MOSI 1 A07
resource SPI_MOSI 2 B15
resource SPI_MOSI 3 C12
resource ESCSERIAL 1 B08
resource ADC_BATT 1 C02
resource ADC_CURR 1 C01
resource FLASH_CS 1 A15
resource OSD_CS 1 B12
resource GYRO_EXTI 1 C04
resource GYRO_CS 1 A04
resource USB_DETECT 1 C05
resource PULLDOWN 1 B08
timer B08 AF3
timer B00 AF2
timer B01 AF2
timer C09 AF3
timer C08 AF3
timer B06 AF2
timer A09 AF1
timer A10 AF1
timer A02 AF2
timer A03 AF3
timer B10 AF1
timer B11 AF1
dma ADC 1 1
dma pin B00 0
dma pin B01 0
dma pin C09 0
dma pin C08 0
dma pin B06 0
dma pin A09 0
dma pin A10 0
dma pin A02 0
dma pin B10 0
dma pin B11 0
feature -RX_PARALLEL_PWM
feature RX_SERIAL
feature GPS
feature OSD
serial 0 2048 115200 57600 0 115200
serial 1 2 115200 57600 0 115200
serial 5 64 115200 57600 0 115200
aux 0 0 0 1800 2100 0 0
aux 1 1 1 1800 2100 0 0
aux 2 2 1 1300 1700 0 0
aux 3 46 2 1700 2100 0 0
aux 4 13 3 1700 2100 0 0
vtxtable bands 6
vtxtable channels 8
vtxtable band 1 BOSCAM_A A FACTORY 5865 5845 5825 5805 5785 5765 5745 5725
vtxtable band 2 BOSCAM_B B FACTORY 5733 5752 5771 5790 5809 5828 5847 5866
vtxtable band 3 BOSCAM_E E FACTORY 5705 5685 5665 0 5885 5905 0 0
vtxtable band 4 FATSHARK F FACTORY 5740 5760 5780 5800 5820 5840 5860 5880
vtxtable band 5 RACEBAND R FACTORY 5658 5695 5732 5769 5806 5843 5880 5917
vtxtable band 6 IMD6 I CUSTOM 5732 5765 5828 5840 5866 5740 0 0
vtxtable powerlevels 3
vtxtable powervalues 0 1 2
vtxtable powerlabels 25 100 200
set gyro_lowpass2_hz = 188
set dyn_notch_width_percent = 0
set dyn_notch_q = 250
set dyn_notch_max_hz = 350
set dyn_lpf_gyro_min_hz = 150
set dyn_lpf_gyro_max_hz = 375
set acc_calibration = 10,-20,26,1
set mag_bustype = I2C
set mag_i2c_device = 2
set mag_hardware = NONE
set baro_bustype = I2C
set baro_i2c_device = 2
set baro_hardware = NONE
set rssi_channel = 9
set serialrx_provider = SBUS
set blackbox_p_ratio = 64
set blackbox_device = SPIFLASH
set dshot_bidir = ON
set motor_pwm_protocol = DSHOT600
set motor_poles = 12
set failsafe_throttle_low_delay = 300
set failsafe_procedure = GPS-RESCUE
set align_board_yaw = 90
set current_meter = ADC
set battery_meter = ADC
set ibata_scale = 479
set ibatv_scale = 479
set beeper_inversion = ON
set beeper_od = OFF
set yaw_motors_reversed = ON
set small_angle = 180
set gps_provider = UBLOX
set gps_auto_baud = ON
set gps_rescue_angle = 35
set gps_rescue_initial_alt = 100
set gps_rescue_descent_dist = 100
set gps_rescue_ground_speed = 1500
set gps_rescue_throttle_min = 1150
set gps_rescue_throttle_max = 1700
set gps_rescue_throttle_hover = 1360
set gps_rescue_sanity_checks = RESCUE_SANITY_FS_ONLY
set gps_rescue_min_sats = 6
set gps_rescue_min_dth = 50
set runaway_takeoff_prevention = OFF
set osd_vbat_pos = 2434
set osd_rssi_pos = 2426
set osd_link_quality_pos = 344
set osd_rssi_dbm_pos = 376
set osd_tim_1_pos = 161
set osd_tim_2_pos = 2455
set osd_flymode_pos = 2137
set osd_throttle_pos = 312
set osd_vtx_channel_pos = 395
set osd_crosshairs_pos = 14541
set osd_current_pos = 2401
set osd_mah_drawn_pos = 2370
set osd_motor_diag_pos = 238
set osd_gps_speed_pos = 2232
set osd_gps_lon_pos = 34
set osd_gps_lat_pos = 49
set osd_gps_sats_pos = 2241
set osd_home_dir_pos = 2414
set osd_home_dist_pos = 2444
set osd_altitude_pos = 2263
set osd_avg_cell_voltage_pos = 354
set osd_esc_rpm_pos = 182
set osd_core_temp_pos = 365
set system_hse_mhz = 8
set debug_mode = GYRO_SCALED
set vtx_band = 1
set vtx_channel = 7
set vtx_power = 1
set vtx_freq = 5745
set max7456_spi_bus = 2
set dashboard_i2c_bus = 2
set flash_spi_bus = 3
set gyro_1_bustype = SPI
set gyro_1_spibus = 1
set gyro_1_sensor_align = CW180
set gyro_1_align_yaw = 1800
set gyro_rpm_notch_harmonics = 1
set name = NOVICE-IV
profile 0
set dyn_lpf_dterm_min_hz = 84
set dyn_lpf_dterm_max_hz = 204
set dterm_lowpass_type = BIQUAD
set dterm_lowpass2_hz = 180
set throttle_boost = 0
set p_pitch = 70
set d_pitch = 52
set f_pitch = 75
set p_roll = 70
set i_roll = 90
set d_roll = 50
set f_roll = 70
set p_yaw = 95
set f_yaw = 70
set d_min_roll = 33
set d_min_pitch = 34
save
Kopterheld Coupons:
https://t.me/s/KopterHeld
https://kopterheld.tv/
My equipment:
DJI FPV Goggles V2 - https://www.banggood.com/custlink/DDmRIkhAdY
Fatshark Dominator HDO2 - https://www.banggood.com/custlink/KmGKeeY4pN
ImmersionRC RapidFIRE - https://www.banggood.com/custlink/vm3v6vafP1
Radiomaster TX16S - https://www.banggood.com/custlink/vGvKMV73QP
CADDX Ratel 2 - https://www.banggood.com/custlink/GDvEFB6wnC
Youtube - https://www.youtube.com/kopterheld
Instagram - https://instagram.com/kopterheld
Twitter - https://twitter.com/kopterheld
New Product Eachine Novice-II 1-2S 2.5 Inch FPV Racing Drone RTF & Fly more w/ WT8 2.4G & Goggles alex_nikiforov Banggood.com 0 Oct 15, 2019 10:40 PM
New Product Eachine Novice-I 75mm 1-2S Whoop FPV Racing Drone RTF & Fly more w/ WT8 2.4G Transmit alex_nikiforov Banggood.com 0 Oct 01, 2019 10:12 PM
Discussion Long range TBS micro bundle..... rhart FPV Racing 2 Aug 12, 2017 09:47 AM
