This thread is privately moderated by oldsneakers, who may elect to delete unwanted replies.
Jun 14, 2021, 12:52 AM
oldsneakers's Avatar
Using a TM1000 with an AR630
The AR630 comes with built in Fly By telemetry for certain items. By itself, it will not do telemetry for the flight pack battery. That will only work if you also have an Spektrum Avian ESC. You can get around that limitation by adding a TM1000 module.
Unfortunately, the TM1000's are discontinued but I do see them for sale on eBay now and then. Similar to the way a AR636 worked with a TM1000, the Forward Programming in the AR630 interferes with the telemetry in TM1000. So I added a Hobby King receiver controlled switch to turn the TM1000 on and off as needed. So you fly with the TM1000 on and shut it off when you need to make programming changes on the ground.
The wiring on this is very simple. A Y servo cable plugs into your available port. You plug the HK switch and a modified servo cable into the Y. You remove the white signal wire from the modified servo cable as shown. Also on that modified servo cable you cut the red wire and solder the two wires of the switch there. When that is done you just plug the other end of the modified servo cable into the TM1000 and it’s all set other than assigning the channel to a switch.
One other thing. You must bind the TM1000 and the AR630 together at the same time. To do that, use a servo 2 way Y cable. Plug the single end of the Y cable into the receiver bind port. On the other two ends, put a bind plug in one and the wire coming from the TM1000 in the other. Hold the bind button down on the AR630 and plug the battery in. Lights on both the AR630 and the TM1000 should be blinking. Go thru the bind process on your transmitter.
https://hobbyking.com/en_us/turnigy-...ucts_analytics
Discussion Using an optocoupler to turn on/off with an AUX switch? kameo Multirotor Drone Electronics 0 Jun 09, 2018 07:07 PM
Help! Which Sail Servos with an arm (not a winch) do you use in your IOM boats? stevepinder Sailboats 26 Dec 29, 2015 06:43 PM
Discussion Can you use AR6210 with TM1000 DSM2 ? kayvannouri Power Systems 4 Aug 24, 2012 04:22 PM
Discussion Can Spektrum TM1000 Be Used With Non-BUS Receiver? NFA Fabrication Radios 5 Jul 24, 2012 10:16 AM
Discussion Is the Spektrum TM1000 compatible with an ET Altimeter? bmitchell138 Eagle Tree Systems 6 Apr 18, 2012 02:14 PM
