Jul 08, 2005, 06:13 AM
Fast and getting faster!
Motor Mounting on a FLiton Prodigy????
I have a fliton prodigy and a hacker 20-20l, and I am lost as how to mount it. I need the motor shaft to stick out past the cowl to fit the spinner I bought, but I am lost as how that can work?
Jul 08, 2005, 07:07 AM
Aio_1's Avatar
Can you give more details such as a picture of the cowl and bulkhead? What type of spinner are you using? Can it take either the 3mm or the threaded adaptor or will it only take one of the two?
Aidan
Jul 08, 2005, 09:31 AM
Scott Stoops
sukhoi26mx's Avatar
You're going to have to engineer a mount for it. The Prodigy was designed with support for only outrunners with raidal mounts. I might consider modifying a Hacker stick mount adapter from Stevens Aero (www.stevensaero.com) and attaching it to the firewall somehow.
Scott
Jul 08, 2005, 10:25 AM
2021 EDF Jet Jam June 10-12
Robert Belluomini's Avatar
The radial mount that comes with the motor works perfectly. This model was designed for the AXI 2212/26 and the Hacker is a great alternative.
Jul 08, 2005, 11:05 AM
Scott Stoops
sukhoi26mx's Avatar
Ah... I thought he had a B20... not an A20...
Jul 08, 2005, 12:09 PM
I figured mounting it radial, but the spinner I have requires the use of the shaft so if I mounted it radial I wouldnt be able to use the spinner I bought.
Jul 08, 2005, 12:48 PM
Dreamin' in 3D
Blackhawk3D's Avatar
It wouldn't work why? Radial mount still has a shaft.
Jul 08, 2005, 02:02 PM
The spinner has an adapter made specifially for the main shaft on the hacker, I dont think the adapter is the same size as the prop adapter in the spinner.
Jul 08, 2005, 02:21 PM
Aio_1's Avatar
You can use the motor shaft instead of the adapter if you choose.
Remove the circlip and use the collar to restrain the shaft at the plate end. Slide the rest of the shaft through to the bell end and moubt with the radial mount. I can't see why you'd have a problem.
Aidan
Jul 08, 2005, 06:00 PM
I didnt realize I could move the shaft?
Jul 09, 2005, 03:25 AM
Aio_1's Avatar
You can. Just loosen the grub screw in the bell hub and remove the circlip. Then you can slide the shaft forward or back in the motor. If the thrust will tend to pull/push the rotor off the motor as it will in your case you'll need to replace the circlip with the supplied collar.
Aidan
Jul 09, 2005, 05:24 AM
Alfo
My PRodigy with hacker A 20/22l
Hi Friends, see picture
Help! Motor Mounting Help on Twin P-38 2dogrc Foamies (Kits) 12 Jul 09, 2006 09:32 PM
AXI motor mounting on an FSK Spitfire; how to jbrundt Parkflyers 7 Apr 23, 2004 08:43 AM
Astro 020 Motor Mounting on Corona Orion_V Electric Heli Talk 8 Aug 06, 2003 12:13 PM
Mounting motor directly on foam Cubby Boy Foamies (Kits) 3 Mar 24, 2003 07:12 PM
motor mounting for mega on zero? kartman24 Parkflyers 15 Jan 30, 2003 04:00 AM
