May 30, 2021, 06:53 PM
Servo brass eyelet positioning
I thought the proper way to install the brass eyelet in the rubber grommet when mounting a servo to a servo tray or against a ply rail was to have the wide bevel down against the ply?
Thanks. "Nitro Pirate"
May 30, 2021, 06:59 PM
OK.., got it... A little bit more research is all.. The wide or hat on the bottom against the rail..
I agree. I saw some photos of some servos for sale & they had em incorrect.
Jun 14, 2021, 09:03 PM
If you have trouble putting those brass eyelets in the rubber grommet you can slide them on a punch then insert them in the grommet.
Question Installing Eyelets? CarreraGTSCS The Builders Workshop 10 Dec 11, 2019 11:26 AM
Discussion Micro servo with 360 degree positioning control matchbox FPV Talk 27 Jul 31, 2017 08:22 AM
Discussion How to set default servo position? fantasydreaming Beginner Training Area (Aircraft-Electric) 10 Apr 14, 2016 12:32 PM
Poll servo eyelets up or down firehorse The Builders Workshop 16 Mar 27, 2012 09:43 PM
Link Servo Mounting Hardware (Grommets, Eyelets, Screws, Mounts, Tape) ServoCity ServoCity.com 0 Oct 13, 2011 09:13 AM
