Blade Heli - LiPo Battery question
Is it possible to use a three cel LiPo battery without changing the main motor?
I added a heat sink to the tail rotor and the main engine and was hoping that this would work without replacing the motor with the hop up version that is available. Will I burn out the stock motor? |
Only if you have a 9 (or 8) tooth pinion you want to 'press onto' your motor.
Running the 10 tooth on 3s is bad.... inefficient, high current, hot, and potentially generates interference (due to excessive current and brush arcing), and will shorten the life of your motor, and could damage the 4 in 1.... Yes, you will dramatically shorten your motor life (and may smoke it). Please use a motor equiped with the proper pinion. Have Fun, David |
As far as I can tell, the "3d kit" upgrade motor is the same motor as stock but it has a 9 tooth pinion on it. I wouldn't call it a "hopup" motor at all. It is critical though, to reduce the teeth on the motor with the higher voltage as stated above. Since horizon seems to be saying to use the 9 tooth pinion with 3 cell, you can't really go wrong
LDC,
Pretty much correct... EFL doesn't call it a Hop-up motor... the collection of parts is called and Aerobatic Enhancement Kit... designed to be used in conjuntion with a quality 3s LiPo. It is the same motor with a different pinion (for a good efficient power match at higher voltage). The AEK pinion is 9 Tooth, 0.5 module as I recall. (stock is 10 tooth). David |
YUP, same motor. BUT a great thing is if you installed the "AEK" right off the bat and you wear this motor out that you can, with the use of a micro pinion puller, swap pinions and get right back in the air. SO keep your stock motor with 10 tooth pinion guys!
I have now logged over 45 flights on my BCP with AEK/TP LI-PO. The AEK motor is still working very well. 1 crash, actually inverted landing in the grass, is the only time the heli landed wrong. I got too low during an inverted hover and just let it kiss the grass. <G> ___________ Best Regards, Ron Osinski aka - GMRO |
i have over 40 full flights on 3s lipos,9 tooth main,stock tail,no problems yet,heatsinks on both,so far,flawless
Thread Tools | |
Similar Threads | |||||
LiPo Battery Question | scar face | Parkflyers | 4 | Jul 13, 2005 08:40 AM | |
Triton Charger and Lipo Battery Question?? | Jagzilla | Batteries and Chargers | 9 | Nov 28, 2004 11:38 PM | |
GWS Lipo Battery question | FDC | Vendor Talk | 1 | Sep 25, 2004 12:23 AM | |
Electric heli motor / battery question. | fxstbi | Electric Heli Talk | 0 | Nov 24, 2002 11:50 AM |
