Zippkits.com - G30 Tunnel Hull Kit
New G30 Outboard Tunnel kits now shipping! Cowls are streaming in as material becomes available.
Now Available!
From Zippkits...
We are shipping as we receive cowlings. This is the new G30 Outboard Tunnel hull from Rod Geraghty and the JAE gang.
Designed for Nitro or Electric power, this new kit features foam core sponsons and quick assembly.
The G30 has been developed to a high level with stock 3.5 nitro and P limited electric power. Use any 3.5 (.21) outboard. The transom is drilled for the OS lower unit.
You can build this boat in a weekend, ready for sealing.
Specs:
  • Length- 30.5 inches
  • Beam- 11.5 inches
  • Weight- (bare hull) 32 ounces
Kit includes:
  • Laser cut 1/8 and 1/16 ply for entire boat
  • 2x Foam cores for sponsons
  • Engine mounting screws
  • Sponson nose blocks
  • Balsa fuselage nose block
  • Lightweight PETG (plastic) cowling
  • Step by step illustrated building and setup manual
Required for nitro version:
  • 3.5cc Nitro outboard
  • 2 channel radio
  • 90 oz/in standard servo for steering (waterproof is best)
  • Mini servos for throttle and mixture
  • 8 ounce fuel tank and fuel line
  • Steering cables or pushrod (and servo mount)
  • 440 prop (Zipp 4007)
Required for FE version:
  • 3.5cc outboard lower unit
  • 2 channel radio
  • 36mm motor with water jacket ( Zipp 635 and 709)
  • 150A speed control (Zipp 705)
  • 4S 5000 mah battery (60C or higher)
  • Servo mount (Zipp 3711)
  • Pushrod and connectors
Both require glue, sealer and paint We recommend medium CA for the fuselage, 30 minute epoxy for sponson assembly and epoxy finishing resin for sealing.
VISIT ZIPPKITS HERE
May 17, 2021, 06:45 PM
I got mine! can't wait to dig into it. Zipp makes some great kits that are super easy to build.
Discussion New boat kits from Zippkits.com oldpa Dock Talk 3 Jun 24, 2017 11:47 AM
Discussion Dilemma - F1 tunnel hull or catamaran as a fist boat :) goshakv Racing Boats - Electric 68 May 16, 2016 10:49 AM
Discussion F1 Tunnel Hull Laser kit motawold Racing Boats - Electric 3 May 15, 2016 12:16 PM
Question DPI Tunnel hull RickerJ Racing Boats - Internal Combustion 4 Feb 06, 2016 12:50 PM
Alert For Sale - New OSSIS-RC F-1 RACING outboard Tunnel Hull Jaguar22 Atlanta Area RC 0 Jan 10, 2016 03:23 PM
