May 17, 2021, 10:19 AM
GymCoach
longer power cable for pixhawk
Does anyone know of where I can get a longer power cable for the pixhawk 1? I need one about 25 cm in length to get from the battery area to where the pixhawk is.
On another note does the power module have to go between the battery and power for the drone or can it just be hooked up to the power of the drone.
thanks ahead for your help
May 18, 2021, 12:10 AM
mlebret's Avatar
If you want to monitor Voltage and Current, Power Module need to be the first in line between Battery and power distribution board. You can use cable extender if needed.
May 18, 2021, 09:33 AM
GymCoach
do you know where i can buy the cable extender?
May 29, 2021, 10:49 PM
FA3PR9WM79
Oldgazer's Avatar
You don't need a cable extender. What you need to do is replace the battery input and out put wires so the power harness will reach the FC.
New Product New V3 3DR Radio Telemetry 433MHz 1000mW with OTG Cable for APM Pixhawk Flight Contro scousethief Banggood.com 0 Apr 25, 2019 05:07 AM
Help! Make your own Telemetry cable for Pixhawk to Frsky X8r rx. savage600 DIY Electronics 6 Jan 25, 2019 03:51 AM
Help! Looking for the power cable to power a fps video transmitter wes709 FPV Talk 7 Apr 18, 2016 09:37 PM
Discussion Fatshark longer cables? power cables, and RCA or AV cables for Ground station? 85miles FPV Talk 1 Jun 19, 2013 10:14 AM
