This thread is privately moderated by old4570, who may elect to delete unwanted replies.
May 08, 2021, 07:04 PM
old4570's Avatar
ELF DLG - 1st launch in over a year
ELF DLG , been a long time (14 min 4 sec)
I really like the ELF , amazing technology built into a 2ch glider .
Lift ? Where is the lift ?
I got teased by some rising air , just a tease . We just dont have much lift around here , lot's of sink , but that lift .
Next time I will try a lighter / smaller battery and have a more rearward CG .
Rusty flying on my part . Quite a few times I pushed the nose over too quickly , I might have got another 10 meters if I did not pull the trigger so early .
May 10, 2021, 04:34 PM
I just purchased an ELF. The fellow who sold it told me I needed a 1S battery, 220-250 mAh.
I have a small box of 150 mAh 1s batteries. Is there any reason I can't use those instead?
May 11, 2021, 09:31 PM
old4570's Avatar
I use the batteries to control my CG ( was assembled that way ) .
I have used a 300mAh Nanotech 1s
Next I will be using a 150mAh 1s no name .
My Elf uses very little energy / battery . A decent 150mAh should give you at least 1 hour . ( If not more ) - Variable being components .
CG is 80mm + or - 2mm , I have been flying at around 75mm .
Which is why I will be moving to the smaller lighter battery for around 80mm CG
Discussion Wild launch after 2 years of being away from DLG Zé Povinho Hand Launch 7 Apr 22, 2021 10:02 AM
Discussion No RC car in 20 years..... I over did it a tad. lol LaserSVT Off-road Cars 13 Jul 09, 2016 07:31 PM
Discussion First Balsa Build In Over 30 Years rainyday101 Balsa Builders 5 Jul 05, 2016 09:17 PM
Discussion 10 year old DLG launching ifome Hand Launch 16 Dec 11, 2011 03:36 PM
Discussion Best DVD to get to learn to fly/launch 1st DLG lmoaks Hand Launch 6 Oct 18, 2010 04:20 AM
