Rotary switch on Taranis X9 Lite
How to use S1, the rotary switch on my Taranis X9 Lite?
I want to use it as a master volume control. When I go to Special Functions to add it, it isn't an option like the rest of the switches; when you move them they appear as the one you want to assign a function to. The instructions only point it out as S1, and don't mention it anywhere. |
S1 and S2 are not normally switches, they are analog inputs, much like a stick/gimbal.
They can be modified to be a multi-position switch, but do not come that way from the manufacture. Has yours been modified? If not: You are probably trying to set the special function as switch, instead use ON for the switch and S1 or S2 for the the parameter. If you set it as a special function, you would have to set it for every model. For my use I set it as a Global Function so it works for every model. (Works the same on a QX7 as an X9D.) |
Reason: Added S1/S2 possibly modified.
Thread Tools | |
Similar Threads | |||||
Discussion | FrSky - Taranis X-Lite - S and Pro - X9 Lite - S - R9M Lite and Pro - MPM Lite | Jet_Flyer | Radios | 4185 | Mar 11, 2024 01:56 PM |
Discussion | Frsky X-Lite and other Taranis (X9 Lite, X-Lite S, X-Lite Pro) | Frimen | Radios | 5015 | Feb 27, 2024 10:10 PM |
Discussion | 3 position momentary switch for a taranis x9 lite-a | Shmebulock | Radios | 8 | Mar 27, 2021 07:45 AM |
New Product | FrSky New Arrival - Taranis X9 Lite & X9 Lite S | AndreaHuang | FrSky | 7 | Feb 15, 2020 06:30 AM |
