| Thread Tools |
| This thread is privately moderated by lawrence4, who may elect to delete unwanted replies. |
Fuselage glued.
Shaped fuselage.
Horizontal tail 3mm balsa
Vertical tail 3mm balsa
Main wing leading edge and middle 5*10mm balsa,
Rib 1 and Rib 6a use 3mm balsa, Rib 2~5 and 7~14 use 2mm balsa, Rib 6b cancel. ImagesView all Images in thread
2mm balsa Ribs shaped and cut notch,
Main wing rear edge use 5*40mm add 5*24mm instead 10*40mm. Main wing tip block: 5*22*160mm + 3*22*160mm + 5*22*160mm |
Reason: Add wing tip block photo
Sandpaper shaped leading edge before cover top and bottom.
Draw aileron position,
Roll sandpaper to mill out carbon fiber tube notch. |
Beam support 2mm balsa reinforced.
Top covered 1.5mm balsa,
Front edge add 5*10mm balsa. |
Aileron Servo EMAX ES08AII 8.5g
Bottom only rib1~rib3 covered 1.5mm balsa. |
| Similar Threads | |||||
| Category | Thread | Thread Starter | Forum | Replies | Last Post |
| Cool | Enterprise-D - Build Log, Plans, Kits, and now a Mini-Version! | SGTalon | Foamies (Scratchbuilt) | 1006 | Feb 04, 2024 05:41 PM |
| Discussion | Y-F23 - EDF Twin 50mm {Modifed version of Craig Clarkstone plans} build log 2 | Strmckr | Scratchbuilt EDFs | 4 | Jul 17, 2016 03:17 PM |
