New Smart G2 Powerstage Bundle For 6S Aircraft
The Smart Technology Powerstage Bundle is a one-box solution for aircraft requiring top performance. Designed with the simplicity of Smart G2 Technology, this bundle includes (1) SPMX56S30 22.2V 5000mAh 6S 30C Smart LiPo G2: IC5 and (1) SPMXC2040 S1400 G2 1x400W Smart Charger to make charging easy.
LINK - https://www.horizonhobby.com/product.../SPMXPSA6.html
Key Features
  • Smart Discharge Allows Batteries to Automatically Discharge to a Safe Voltage
  • Integrated Microchip Stores Unique Parameters for Each Battery
  • Spektrum Smart Technology Makes Charging and Maintaining Batteries Easy
  • Auto Charge recognizes Smart battery charging parameters and begins safe, accurate charging automatically when connected
  • An on-screen clock counts down remaining charge time until your Smart battery is fully charged and ready to use
SPEKTRUM SMART CHARGER With its 400W power, improved user interface, and ability to fast charge Smart batteries on either the IC3® or IC5® integrated output port, the S1400 charger offers a versatile and truly hassle-free charging experience. You can charge virtually any RC battery with the S1400 charger. Use it together with Smart G1 or G2 batteries and you'll be amazed by its incredible functionality and performance.
  • Allows hyper-fast charging with up to 400W power
  • Charges AND balances Smart G2 batteries with one simple IC3® or IC5® connection — no separate balance lead needed
  • Includes IC3® and IC5® charging output ports — no separate adapters required to charge different Spektrum™ Smart batteries
  • USB input and output ports are included for updating firmware and charging secondary devices
May 11, 2021, 10:12 AM
These G2 lipos can't be charged on other brand chargers without the balance lead. So if you forget your charger and none of your buddies have a smart charger, that's it.
May 14, 2021, 07:52 PM
mumblety-peg's Avatar
I like the idea. But cannot commit to using just SMART batteries if it means being locked into a single manufacture. I have one SMART battery (Not the G2). Weight and price are very good. Hopefully it will be reliable.
As to the charger... I hate the wheel used to make selections. And the charger just has a cheap feel to it. This said... it is inexpensive. And it seems to have all the features I need aside from one.
If you only have smart batteries, then the charger can do all you need to do. Big down side to this is that there is no regen discharge. Discharging a big pack to storage would take too long. Again if you use just SMART batteries this is no an issue.
Article Smart Technology Contest! SPMXC2020 Smart S1200 G2 AC Charger Jim T. Graham Batteries and Chargers 415 May 24, 2021 08:47 AM
Discussion New G2 S1200 AC 1x200W Smart Charger alex24 Radios 2 Apr 07, 2021 04:56 AM
Discussion A.K.E. G2/P6 Smart Port - Anyone Use One Of These? Keven_C Batteries and Chargers 0 Nov 08, 2007 04:16 PM
GWS Aircraft availability for Real Fight G2? mattski Vendor Talk 0 Sep 05, 2003 01:49 AM
