This thread is privately moderated by dodgeit, who may elect to delete unwanted replies.
May 04, 2021, 09:12 AM
Trader Rating: 30
$60.00 USD
Seller Pays Shipping
For Sale
Castle, JETI, Soaring USA Switches, voltage regulator All new in pack
First up is a JETI MAX BEC 2D plus EX
The Jeti Max BEC 2D Plus EX is the latest linear voltage regulator from Jeti, produced to very high standards in Europe. The Max BEC 2D Plus features a magnetic switch, so there is no mechanical wear-and-tear from switching the unit on and off. The unit also has a large heat-sink to dissipate heat. The maximum burst output is 20A. The recommended input power is 5.5-8.4V, e.g. two-cell lithium polymer batteries or 5-6 nickel-based cells. You may also use 2-cell LiFe battery pack. Sells for $95 new
Next up is a Small Charge Plug Switch from Soaring USA
This small Charging Jack and Power Switch (ChPS) is a great way to integrate both functions into one reliable unit.
The socket can be mounted anywhere you like, including through the fuselage. When the plug is inserted, the power o the receiver is turned off, and the pig tail can be used for charging and/or discharging your receiver pack. When the plug is removed the receiver is turned on.
Very simple, time tested design, built to the standards you have come to expect from us. It even has a little streamer on it so it won't get lost.. :-)
PROUDLY MADE IN THE USA WITH SWITCHCRAFT PARTS!! :-) Sells new for $30
And then we have a Castle Creations ARMING LOCKOUT HARNESS AND KEY W / LANYARD ASSEMBLY
The Castle Creations Arm Lock Key Harness attaches to the AUX LINE (On Phoenix Edge ESCs) and the receiver, and is designed to act as an extra safety measure while operating your RC Heli or Airplane*. When the key is fully seated into the socket, the controller will be incapable of arming. Once the key is removed, the ESC will arm when it receives the low throttle command on the traditional throttle line. If the key is inserted while the motor is running, the ESC will go into the ARM LOCKOUT state stopping the motor from running and preventing the ESC from arming. Sells new for $17
All three shipped inside CONUS with tracking for $60.00, shipped in the lower 48. Will not separate.
PM with questions
For Sale Switches, voltage regulator All new in pack JETI, Soaring USA, Castle dodgeit Aircraft - General - Radio Equipment (FS/W) 0 Apr 30, 2021 05:12 AM
For Sale Switches, voltage regulator All new in pack JETI, Soaring USA, Castle dodgeit Aircraft - General - Radio Equipment (FS/W) 0 Feb 11, 2021 07:02 AM
Sold 2 - mpi voltage regulators & miracle switch, (new in package) rnewland Aircraft - General - Radio Equipment (FS/W) 1 Apr 10, 2019 09:33 AM
For Sale Jeti Voltage Regulator SBEC 40 5-8V/40A w/Magnetic Switch tnaero Aircraft - General - Radio Equipment (FS/W) 0 Jan 04, 2019 09:03 PM
Discussion Are there any downsides to using higher voltage packs and a voltage regulator? FastMinis Batteries and Chargers 3 Jul 02, 2016 06:22 PM
