Apr 30, 2021, 11:03 AM
Engine recommendations
Looking for input on engine recommendations for a Stinson SR10. This is a 125Ē WS, 34 pound plane. I just purchased the kit and obviously have quite some time to purchase an engine but am not sure what to get. I would love a 3 cylinder radial like the Saito FA450R3 but donít know if it has sufficient power for this application.
Any insight would be greatly appreciated!
Thanks in advance,
Curtis
Apr 30, 2021, 11:22 AM
JimboPilotFL's Avatar
Here is one on YouTube with an 80cc gas twin cylinder. Seem about right.
Stinson Reliant SR-10 - Maiden Flight (7 min 22 sec)
Apr 30, 2021, 11:24 AM
Awesome. Iíll check it out. Thanks
Apr 30, 2021, 03:24 PM
koppterX's Avatar
what an incredible project. i think a 80cc to 100cc would be about right. i have an 85cc on a 122 Decathlon but it's under 30lbs and is quite aerobatic. If you are pushing 35 lbs I wouldn't rule out a DA 100 or something similar. Radials are way cool, Moki has some big ones.
Apr 30, 2021, 03:38 PM
A man with too many toys
You need a Saito FG-73R5 73cc 5-Cylinder radial. Next shipment is June so get on the lost before they are all spoken for. Check the measurements to see if it will fit the cowl.
I am thinking of getting one just to have it on hand. No telling when they will stop making them.
Apr 30, 2021, 03:47 PM
Still gassin' it.
For a radial, I would probably go for the higher side. of 100 cc displacement: Fourstrokes are less powerful than equal displacement 2-strokes, and radials are less powerful than twins or singles of equal displacement.
That IS most definitely a good looking engine (and so far none of the scary stories like the triples), but for a plane like in OP, I would probably go for a 125 cc radial at least. IF it had to be a radial...
koppterX's Avatar
I want to add that 35lbs seems wildly optimistic. I’m thinking mid to high 40s.
73R5 Dimensions:
Looks like it's 230mm diameter.
Apr 30, 2021, 03:48 PM
Still gassin' it.
Originally Posted by koppterX
I want to add that 35lbs seems wildly optimistic. Iím thinking mid to high 40s.
Dunno... the plane in post 2 is claimed to be 130+" wingspan and only 28 lbs...
Apr 30, 2021, 03:57 PM
koppterX's Avatar
Not a chance that’s correct. 35% aero bats with wingspans of 105 in are 28 ish. And they’re light.
Apr 30, 2021, 04:08 PM
https://www.youtube.com/watch?v=qJhgfY2v0As&t=1s
I have always thought that those big 2-stroke gassers were way too noisy. Get a 4-stroke!
Apr 30, 2021, 05:11 PM
Very nice looking!!! Appreciate the info.
Apr 30, 2021, 05:13 PM
That was my thoughts also. Would need to go bigger in a four stroke to make it work!
I’m not dead set on a radial just love the way they sound!
What problems are you referring to with the triples?
Apr 30, 2021, 05:15 PM
Iím not sure of the weight. Just quoting the websites advertised weight.
Apr 30, 2021, 05:17 PM
73R5 Dimensions:
Thanks. The kit is supposed to arrive Sunday. Iíll check the measurements.
Question What gas engines would you recommend for this configuration? LuftwaffeSS Engines 20 Aug 18, 2021 11:27 AM
Question Can you recommend a small gas engine to replace .45 glow? XRAYRON Fuel Plane Talk 12 Feb 12, 2016 04:55 AM
Question gas engine recommendation for 77" Aviator ? tilleymj Engines 11 Oct 17, 2015 03:41 PM
Discussion Size tug plane recommendations for 99 cc Stihl engine. Jim.Thompson Fuel Plane Talk 23 Oct 15, 2015 08:58 PM
Help! .40-.46 Glow engine recommendation for seagull boomerang 40 SamuelWyatt123 Engines 2 Oct 07, 2015 03:05 AM
