Apr 14, 2021, 06:59 AM
Bell runout
What effect does bell runout have on your ESC ,
is it irrelevant until the magnets touch the stator
Apr 14, 2021, 08:57 AM
Depending on the RPM my concern on bell run out would be the effect on the balance.
Less likely it could effect the ESC as the coils furthest from the magnets might produce a weaker synchronising signal so the ESC may loose its timing.
More of a concern is what causes the run out? Bent shaft? Damaged Bell? It might be prudent to simply replace the motor.
Apr 15, 2021, 11:19 AM
Jack
jackerbes's Avatar
It might be that the shaft has moved in the magnet housing motor base and just needs to be reset to the right position. This thread has the details on doing that:
Outrunner Disassembly and Stripping - Gimbal Motor Rewind -
https://www.rcgroups.com/forums/showthread.php?1823636
Jack
Apr 17, 2021, 01:48 AM
weight imbalance. magnetic imbalance. inefficiency.
Question Octoprint with BTT Smart Runout Sensor Komikaze 3D Printing 1 Nov 23, 2020 08:42 PM
Discussion Motor Shaft Runout 5artist5 Multirotor Drone Electronics 1 Oct 07, 2015 08:57 PM
Careful! Outrunner Rotor Runout INewton Electric Motor Design and Construction 14 Feb 02, 2006 10:29 PM
Discussion Corona tail rotor runout rchawks Electric Heli Talk 2 Jan 21, 2006 04:42 PM
hacker b20L GEARBOX RUNOUT grr1941 Foamies (Kits) 2 Aug 07, 2002 06:41 PM
