FrSky Xact Series Glider Servos 5701
NEW ARRIVAL - FrSky Xact Series Glider Servos 5701 in stock now...
The Xact series coreless servos utilize all CNC machined aluminum protective case and metal gears, the Xact 5701 servos are 3.5V to 6V wide voltage capable and offer high speed and configurable torque performance. Also, the Xact series servos offer multiple form factors and configurations to fit different model types and precision usage.
Working with the F.Port 2.0 (FBUS) protocol, the telemetry data (like real-time current and voltage) of Xact servos can be achieved and transmitted back to the radio by connecting either F.Port 2.0 capable receiver or flight controller. All the preset servo options of speed and torque can be configured directly on an ACCESS radio through the host device of the F.Port 2.0 line, and the configurable servo steering as well as travel degree are additions now can be expected on this series.
FEATURES
  • For F3K DLG
  • 6.5g weight & 6mm thick
  • Speedy Response
  • Incomparable Torque Performance
  • High Precision with Zero Slop
  • The Best Positioning Accuracy of Central Point
  • Built-in Hall Sensor
  • Programmable Travel Angle
  • Robust CNC Aluminum Case with Metal Gear
SPECIFICATIONS
  • Torque @ 3.7v 1.40 kgf.cm / 19.4 Oz-in
  • Torque @ 4.8v 1.80 kgf.cm / 24.9 Oz-in
  • Torque @ 6.0v 2.30 kgf.cm 31.6 Oz-in
  • Speed @ 3.7v 0.16 sec/60
  • Speed @ 4.8v 0.12 sec/60
  • Speed @ 6.0v 0.09 sec/60
  • Dimensions: 20.2*6*23mm (L*W*H)
  • Weight: 6.5g
  • Voltage: 3.5 6.0V
  • Telemetry: Current / Temperature / Travel Angle
  • Frequency: 1520us / 333Hz, 760us
  • Dead Band: 0.001ms
  • Bearing Ball / Gear: Metal
  • Motor Type: Coreless
  • Servo Horn Spline: Φ4 15T
  • Programmable: Yes, Travel Angle
  • Port Type: F.PORT2.0 (FBUS) / PWM / SBUS
Learn More
Check out all the servos at FRSky.
Apr 14, 2021, 08:52 AM
rpstar's Avatar
Could be interesting depending on price as glider specific servos are usually super expensive.
Apr 14, 2021, 01:00 PM
I'm always confused by F.Port. What is required to actually set it up with these servos? Do you have to run extra wires and solder to the pigtail that is included with all the receivers...or does it "just work" off the standard +/-/signal wires?
Apr 15, 2021, 08:33 PM
Gratter's Avatar
They look exactly like the KST servos. Are FrSky and KST the same company?
Apr 16, 2021, 04:00 AM
I'm a balsa butcher
KST's smallest servo is 7mm thick.
Apr 16, 2021, 07:47 AM
eitanro's Avatar
Most of their servos look like a replica of KST with one difference of using s-bus/f.port.
Even the color scheme is exactly the same
Apr 16, 2021, 08:03 AM
I don't want to "Switch Now"
pmackenzie's Avatar
Having SBUS would certainly make a 4 servo wing easier to do.
Apr 16, 2021, 01:18 PM
supreme being of leisure
ZAGNUT's Avatar
hall effect position sensor, that's a game changer for sure!
IIRC KST balked at doing a 6mm servo because of no available pot with decent enough performance...and the x06 ain't that great at centering because of the same.
now just ditch the cheapo pager motor, find something brushless and we would have the ultimate micro servo!
New Product Xact Servos by FrSky target FrSky 76 Apr 18, 2021 08:35 AM
New Product FrSky Xact 5701 6.5g Weight & 6mm Thick Telemetry Servo for DLG & its Relevant AndreaHuang FrSky 3 Apr 17, 2021 03:49 PM
Discussion FrSky Xact Servo firmware update ? Ashley123 FrSky 1 Nov 20, 2020 09:00 PM
Build Log FrSky Xact Series Micro HV 8.4V Capable Servos HV5201/5202/5203 Drinnon Hobby Stores 1 Oct 19, 2020 08:59 AM
News FrSky Xact Series Servos Jason Cole Servos 5 Aug 18, 2020 07:52 PM
