This thread is privately moderated by mdavies, who may elect to delete unwanted replies.
Apr 12, 2021, 09:52 AM
Trader Rating: 58
Michael
$40.00 USD
Buyer pays shipping
Sold
Guillows Pre-built 400 kits
I built 4 of the Guillows WWII 400 series kits over the winter, and want to sell them off
P-40, P-51, Spitfire, Spirit of St. Louis
I have the P-40 Pics posted, this was designed as R/E/T
-this was built and covered in light silk (applied wet) then 2 coats of Easy Dope
-can be finished with Liquidtex Spray, Krylon, or acrylic base paints
-firewall glued in place
-added 1 inch to recommended dihedral
-rudder/elevator built extra solid versions
-includes canopy, and all other plastic parts and build plans
-main wing is held in place with rubber bands, hold downs are carbon fiber
-fuse has sheet balsa around nose, along wing and where hold downs are
-dihedral brace was modified by sheeting top and bottom areas of wing
-wing fairings have not been installed
-AUW is right around 3 ounces as she sits
-perfect for 3.5gram servos and a blue wonder or any 15-20 gram brushless set up
Shipping will run around $17.00
Apr 13, 2021, 02:58 PM
Trader Rating: 1
Do you have pics of the spitfire ?
Apr 14, 2021, 08:13 PM
Trader Rating: 58
Michael
Yes, I will post the spitfire tomorrow. It was done in light tan/green camo and flies with rud/elev/throttle...AUW is under 4 ounces
For Sale No Limit Katagorie 400 Slow - Park Flyer Pre Covered Kit fluxcapacitor121 Aircraft - Electric - Airplanes (FS/W) 5 Apr 21, 2017 11:00 PM
Announce Old Comet, Guillows and Easy Built wood kits available Gordysoar Balsa Builders 8 Sep 23, 2015 10:34 PM
Announce Kits from estate, Guillows, Comet, Easy Built Gordysoar Free Flight 1 Sep 21, 2015 08:37 PM
Sold Pre Built, Pre Covered Sig Somethin' Extra Kit and OS .46 AX2 FlyLowFlyHard Aircraft - Fuel - Airplanes (FS/W) 0 Mar 09, 2015 08:47 PM
Sold Pre Built, Pre Covered Sig Somethin' Extra Kit and OS .46 AX2 FlyLowFlyHard Aircraft - Fuel - Airplanes (FS/W) 0 Mar 04, 2015 06:14 PM
