Counter rotating prop torque?
I am having a problem with the motor/prop torque and its effect on roll stability. Due to the planform, AR, and general size of the aircraft, the configuration is not that inherently stable. I was thinking about using a counter-rotating prop to neutralize this effect.
Would using a counter rotating prop neutralize the net torque of the system, or would there still be torque unaccounted for that would add to rolling moment? Also, are counter rotating props significantly less effecient that a conventional propulsion system? If the new 3.5 g brushless motors weren't so light and powerful, I would just go direct drive, high RPM with a small prop. However, these motors have a low motor kV, so using a small prop is not possible. Any input would be welcome. Thanks, John ![]() |
John - I do not believe there will be any torque associated with a counter rotating prop system, or if there is, it will be negligible. If you use two seperate motors, there could be a slight difference I suppose. j
In regards to efficiency, the rear prop expieriences turbulent air from the forward prop, so people tend to run a slightly higher pitch on the rear prop for best performances. Also, if you are using a single motor with a gearbox to drive two props, there will be some losses associated with friction. I dont know how big a motor you are thinking of using, but here is a twin motor, counter rotating gearbox system I made for pager motors. Cheers, Chris |
Counter rotating props generally means a plane with two props spinning in opposite directions... like the P38 I think that is what indorff is talking about.
Contra-rotating props share the same axis as in the Bladerunner-Heli, or this motor, 16 grams. https://www.rcgroups.com/gallery/sho...cat=500&page=1 the torque is cancelled by the system, But there is also the Coriolis effect to consider jimbo http://www.ems.psu.edu/~fraser/Bad/BadCoriolis.html |
The contra-rotating system I presently fly has proven absolutely flawless. Many hours on two different test vehicles have proven it out and unit two will be going in a full scale Convair Pogo. Search the sites for contra-rotating props as there is a wealth of details available. Also, have found that the #2 prop of a greater pitch only adds amps to the pull and normally provides less thrust overall. In theory this should prove out and may do so at high speed but at low speed and high AOA this does not prove out. Present system produces over 14 ounces of thrust and is torque free. VTOL off and back on to the deck is a matter of practice. Normal high AOA is flown to within a foot of the deck, stabilize, decrease throttle and land on caster. Its that easy, aerobatics are simple, roll response is equal right or left. As the man said "it works for me". ed
![]() Chris |
The first full bodied bird is almost pure scale in outline and is constructed of blue foam and quite a few man hours expended. The second bird will be enlarged 10 percent and be molded of depron foam and should be very light. Canopy plugs are done to pull the clear canopy that will have the pilot rotate from the vertical like the real bird and should come in at under 10 ounces. We had the blue foam bird at Small Steps but haven't had a lot of time to get things finalized. Airframe still requires finish prior to paint but hopefully will be ready to fly before summer is out. Depron bird to be ready by first of year.
ed |
Thread Tools | |
Similar Threads | |||||
3 Bladed Prop Counter Rotating. Design help wanted | TomHH | Modeling Science | 20 | Jun 15, 2015 03:38 AM | |
Question | Counter rotating prop with collet type adapter? | der Oberflügel | Power Systems | 3 | Apr 14, 2007 09:34 PM |
Counter Rotating Prop Drive - redux | GWFAMI | Power Systems | 0 | Aug 02, 2005 11:14 AM | |
Counter-rotating prop? | f2racer | Electric Plane Talk | 1 | Sep 01, 2002 08:00 AM |
