The P8 stepper actuators are complete, self-contained linear motion devices. It comes in 10mm, 25mm, 50mm, 75mm and 100mm stroke length options to allow these to fit a wide variety of applications. The brushless stepper design makes the P8-ST one of our longest life actuators.
The P8 stepper is designed to push or pull a load axially along its full stroke length. The speed of travel is determined by the step frequency, and maximum force by the current applied. When power is removed the actuator will hold its position, unless the applied load exceeds the back drive force. Actuators should be tested in each specific application to determine their effective life under those loading conditions and environment.
For questions about our products, you can call our sales department between 6:00am and 2:00pm Monday through Friday and we'll be happy to assist you.
All of our linear actuators come with a hardware kit to make mounting easy.
Go to Actuonix for pricing and more specs.
Thread Tools |
RCG will take anyone's money. They don't list dimensions, There PQ8 which is smaller is 15mm thick. That's not micro, That's porky. Why are they advertising to modelers again.
Thread Tools | |
Similar Threads | |||||
Gallery | Stepper motor coil actuator in action | mrexcel | Scratchbuilt Indoor and Micro Models | 0 | Apr 07, 2018 09:10 PM |
Discussion | Actuonix linear servo | patmat2350 | Dock Talk | 18 | Feb 03, 2018 03:13 PM |
Discussion | Linear Actuators, what to do with? | vic20owner | Robotics | 0 | Nov 02, 2015 07:49 AM |
Micro Linear Actuator | SpiderDragon | Scratchbuilt Indoor and Micro Models | 4 | May 02, 2005 04:14 AM | |
Can "Smoovy" Linear actuators be adapted as micro Servos?? | JonB | Scratchbuilt Indoor and Micro Models | 2 | Apr 05, 2002 05:17 PM |
