Checking patterns
Well just a quick check on patterns and see if any new patterns emerge from overlapping. This way I’m not waisting tape and time. But it’s time to mask and spray.
Latest blog entry: The "Six" Delta Dart
Mask 1
First mask
White applied
Well white has been applied. Now unwrap and then rewrap for next colors and logos. Well let this dry for a few days and then I’ll mask the next areas needed for paint.
Mask 2
Well laid down some of the black and then diluted the black to dirty the nacelle and canopy area before I put another color. I’m going to make a checker pattern on tails and then dust a gradation of the red going from tail next to nothing and going towards the nose full coverage. Still need to make masks for verticals.
Adding a little movement
Putting a checker pattern on silver and then spray red for front to tail with a mist. Pull the mask and silver will be solid and red will go from solid to faint red mist. Well that’s the plan and then need to do the red on canopy area and left wing logo. Let this dry and then clear top and flip and finish the bottom of the Roo.
Still need to frame
The canopy will have a red band and will surround the canopy area and the define the canopy foe glass with red frame. Frisketing the squares now. Would be easy to just go solid red but just trying another technique.
It begins
Well starting to cut now. Drew up some checker patterns for the verticals. See if this works or not soon.
One side
Side one masked. Need to do second vertical and then bring out some paint. Pspsps
Paint
Well I’ve painted the vertical fins and still need canopy area and nacelle masked and then apply some more red. Logos still need to be applied on wing tops.
Spray
Hello Phil,
I use a respirator and usually use my shop area. I’ve used outside pop up for larger projects. But nothing fancy. So lot of color sanding and then clear and I hope that seals the deal on paint. |
Masking
More masking and some paint.
Still a ways to go but getting closer. |
Thread Tools | |
Similar Threads | |||||
Discussion | [B]Eagle carries off policeman's adopted kangaroo"[/B] | Mark Powell | Life, The Universe, and Politics | 36 | May 05, 2016 08:05 PM |
Discussion | Kangaroo PC | Zaurak3 | Life, The Universe, and Politics | 5 | Mar 09, 2016 03:44 PM |
Careful! | Kangaroo Avoidance | Big Foot 48 | Life, The Universe, and Politics | 8 | Nov 18, 2015 09:06 PM |
Cool | XK123-XKAS350 repainted | GlobeMasterIII | Micro Helis | 8 | Oct 23, 2015 12:05 PM |
