Armsoar - Applying a Gap Seal on a Discuss Launch Glider
Here is a great how-to from Armsoar...
Gap Seal How-to
From Armsoar...
Gap seals on RC gliders, and specifically discus launch gliders, are typically made with tape over the hinge for light weight. The top cavity of the hinge line can occasionally trip the airflow too early, usually in the launch and high speed flight envelope, meaning less launch height and less penetration. It is essential to apply gap seal on a hollow-wing DLG, but on the other hand, the cavity on a solid core model might be beneficial in slower flight regimes.
To get the most performance out of your model, you will need to test whether the gap seal is an improvement or not for your particular model and setup. To do so is easy:
  1. Without gap seals on your model, set it up for straight and true launches, and straight level hands-off flying,
  2. Apply gap seal to one side of your wing (in this example, let us say we have applied it to the right wing panel).
  3. Now do some launch testing: if it veers to the left slightly, it means the gap seal is decreasing the drag on the right wing panel... GOOD! If it veers to the right, it means the gap seal is increasing the drag on the right wing panel... BAD! *don't use your trims to adjust any steering, your model should already be trimmed straight in step 2*
  4. Now do some flight testing: let your model fly hands off, just like it was trimmed to do in step 2. Does it hold the line? Or does it start veering? If it holds the line, the tape is not affecting its flight behavior... not bad (especially if noted that it is increasing launch performance). If it veers left... even better! That means not only is it increasing your launch performance, but also your flight performance. If it veers right... that means it is decreasing it's flight performance.
Applying Gapseal (2 min 15 sec)
Now, with data from steps 3 and 4 on hand, you can decide whether to take off the gap seal, or to finish application on the other side!
Visit Armsoar
For more great info like this visit the site!
Apr 03, 2021, 10:16 AM
Great info. Thanks
Help! Best Way to Gap Seal on a wing old1104 Sailplane Talk 5 Jul 17, 2014 02:43 PM
Discussion Gap Seals On Solid Core Wings BavarianCharles Hand Launch 13 Apr 19, 2014 11:17 AM
Discussion Gap seals on Stobel V2? 1900 Driver Hand Launch 21 Feb 01, 2012 11:28 AM
Discussion Gap seal on flaps and ailerons Rob AR High Performance 16 Dec 30, 2006 07:29 AM
Best motor for Discuss launch glider conversion? MG1500 Electric Power Systems 3 Jul 29, 2003 01:50 PM
