For almost fifteen years the PowerBox DigiSwitch has represented the standard for small to medium-sized models thanks to its compact format and versatility.
By using the latest components we have been able to reduce the size of the Digi-Switch V2 by about 20 %.
The introduction of a top-quality aluminium case, machined and anodised, has brought a substantial increase in the unit’s cooling efficiency, with the result that the maximum continuous current capacity of the PowerBox DigiSwitch V2 is around 20 % higher. In fact, the peak load capacity is twice as high: the DigiSwitch V2 can handle more than 10 A for several seconds!
Powerbox Digi Switch V2 (4 min 43 sec) |
The DigiSwitch V2 offers four user-selectable output voltages: for normal servos it can be set to a regulated 6.0 V, regulated voltages of 7.0 V and 7.6 V are available for HV servos, as is an option for non-regulated voltage.
Power to the unit can be drawn from four different battery types: LiPo, LiIon, LiFePo, NiMH. Ultra-bright RGB LEDs are fitted to indicate battery voltage; they light up in various colours to display the charge status of the batteries.
CORE users also benefit from one special additional feature: the battery voltage and regulator voltage can be displayed directly at the transmitter via telemetry!
Thread Tools |
Bought one recently for a new F3A project. The new switch is very light and easy to program. The led‘s are very bright too.
Excellent value for the bucks |
Thread Tools | |
Similar Threads | |||||
Discussion | DigiSwitch v2 Alternative? | DrPlague | Power Systems | 6 | Jan 25, 2021 03:24 AM |
Discussion | Powerbox systems in combination with SBEC | bartk | Power Systems | 2 | Apr 30, 2018 08:48 AM |
Discussion | iGyro by Powerbox-Systems Or Bavarian Demon Cortex | WattsinThat | 3D Flying | 0 | Mar 22, 2015 08:42 PM |
News | PowerBox Systems GPS II | ndfly700 | Electric Heli Talk | 0 | Jan 06, 2015 10:26 AM |
Discussion | Powerbox system? | bevar | Xtreme Power Systems | 1 | Jul 06, 2007 11:48 AM |
