Apr 29, 2021, 08:50 AM
EMAX Babyhawk 2 HD - Flywoo 18650 Lionpack - 16 Minute Flight (3 min 50 sec)
Apr 29, 2021, 08:43 PM
EMAX Babyhawk 2 HD - Tunnel (3 min 25 sec)
Apr 30, 2021, 06:51 AM
EMAX Babyhawk 2 HD - DJI V2 Goggles DVR Clips (5 min 57 sec)
May 05, 2021, 05:56 PM
Looks like you are having fun with the babyhawk tp...
I'm hoping your knowledge of the little beast might help me have a little more fun, any ideas why it might be stuck in low power mode?
It's not overheating, it's on the latest firmware and I did the region hack (creating the text doc etc) so I'm a little stumped!!
May 05, 2021, 06:38 PM
Learning to crash
Tom T's Avatar
Have you turned off temp control? Doesn't it remain in low power until you lift off, then goes to 700mw if its selected.
May 05, 2021, 08:05 PM
hey thanks badgio yeah try what tom said i believe mine is set to auto temp off and says low power mode until i arm, then when i arm i see it switch to 120fps green box in the lower right hand corner, dvr then starts recording automatically to the sd card from that point until i disarm, which i believe you should be able to configure within the goggles display menu, hope you get it sorted out
May 05, 2021, 08:07 PM
EMAX Babyhawk 2 HD - Dark Sky (5 min 28 sec)
May 05, 2021, 11:57 PM
Thanks guys...
I'll give that a go!
May 09, 2021, 11:27 AM
Weirdly the quad is now in full power mode... And I made no changes! ��
But one more question for you clever chaps. It seems to go bonkers when I land, no matter how softly it starts bouncing up and down like a lunatic...
The guys at the shop where I bought it say it's normal, is that right ?
May 09, 2021, 11:40 AM
Glad you got it into full power mode however it happened 👍🏼
Re the bouncing when landing, not sure if its normal or not, but yeah mine does that too. I just try to time hitting the disarm switch just before I touch the ground
May 20, 2021, 08:58 AM
I can't get a GPS to work via Softserial. Has anyone succeeded? Even on the RGB (LED_STRIP 1 A00) you can't put a "resource SERIAL_RX 11 A00". Apart from the fact that it does not work in conjunction with "resource SERIAL_TX 11 A02", you no longer have a voltage display because A00 is also occupied by "ADC_BATT 1". I hope that someone has got further. With a development time of 2 1/2 years, Emax could have written a proper manual, including instructions on how to get GPS Rescue up and running ........ but there wasn't enough time.
Edit: Does anyone know which pad is " CAMERA_CONTROL 1 "? B10 seems to be occupied only once.
May 20, 2021, 09:21 AM
Delete
May 20, 2021, 01:51 PM
(͡ ͜ʖ ͡)(͡ ͜ʖ ͡)(͡ ͜ʖ ͡)
JohnCC's Avatar
I ordered one, excited to try this form factor The TBS crossfire version came in stock on BG and I got a great deal on it. Now to wait for it to come in on the slow boat. Also, the props for this finally came in stock locally too -- I held off, because I didn't want to buy a quad that I wasn't going to be able to buy the correct props for.
May 21, 2021, 06:15 AM
You were "lucky" again, the sale was discontinued at Banggood. After such a short time ......, was there too many complaints? By the way, the propellers were available from Ali right from the start.
May 21, 2021, 12:51 PM
JohnCC's Avatar
I think it simply went quickly, I got it for $30 off the whole deal, so it was really enticing.
I didn't know the props were also available at aliexpress, but that's good to know as well.
Discussion Emax TinyHawk - Family- Racing Whoop? (1-2s) v2 & FreeStyle (II) TinyHawk II & Race Frimen Micro Multirotor Drones 3134 Jun 21, 2021 11:13 AM
New Product EMAX BabyHawk HD 2 MultirotorDrones Micro Multirotor Drones 91 Jun 13, 2021 12:25 PM
New Product Emax Babyhawk II HD fpvcooper Banggood.com 2 Mar 16, 2021 03:05 AM
