This thread is privately moderated by apus apus, who may elect to delete unwanted replies.
Mar 16, 2021, 11:56 AM
c 27 plans
Here are some pictures that hopefully can add some explanation to the plans.
The electronics on my plane is:
2* 30 gr 1900 kv brushless, but it hovers on half throttle, so I think 1500 kv is much better.
I use a 750 mah 3 sbattery with high c rate ( flight times 6-7 minutes)
Esc are 15 A.
Servoes are 6 gr, but 9 gr are also ok.
All up weight is approximately 600 gr, but I have flown with a camera weighing 120 gr, so it could fly heavier than this. But weight is critical for slow flight.
I have flown this a lot, as you might guess from all its scars. It takes some time to learn to fly it slow, because you need to move the cg backwards and it must be flown with careful throttle corrections. But I am not a 3 d pilot, and I can still easily fly it in walking speed. I have experimented with different set ups on the controll surfaces, but I think one should start with small throws and gradually increase.
Apr 17, 2021, 08:38 AM
Slow Flight
Fantastic, I was waiting for this one. Thanks!!!!!!!!
Apr 18, 2021, 04:40 PM
Slow Flight
Are those flaps or ailerons? I am confuse.
Apr 20, 2021, 10:45 AM
Those are flaprons,
Mini-HowTo Scratch Build - KFM Airfoil,Pusher,Styrofoam amit rc Foamies (Scratchbuilt) 0 Nov 02, 2017 09:23 AM
Discussion Kline-Fogleman (KFm) Airfoils - HIGH POWER pardshaw Foamies (Scratchbuilt) 102 Jun 02, 2017 01:20 PM
Discussion AMA article about the KFm airfoil and our Dickaroo available online at RCGroups basicguy Foamies (Scratchbuilt) 0 Jul 25, 2016 06:35 PM
Question Kfm airfoil ailerons lpd The Builders Workshop 2 Dec 18, 2015 06:53 AM
