Apr 22, 2021, 05:15 PM
A-6 & B-47 OCD
FliteMetal's Avatar
Celluloid 6's
All those pics from the movie are buried in Kentucky. I'll see if Sam can get to them...
Apr 23, 2021, 10:05 AM
A10pilot's Avatar
Ed, thanks for the info. I have a bunch of photos of the filming at China Lake but have not been able to find them. They are packed away in storage but I will try to find them and post here.
Might be interested in one of the 6's if it fits my budget. IF I get one it will be turbine powered.
Thanks again,
Ed
May 01, 2021, 10:41 AM
A-6 & B-47 OCD
FliteMetal's Avatar
Access...AKA Retract, EDF Cradle, & Bulkheads
Description:
With the left gear access now the rear bulkhead, EDF cradle, and gear mounting rail templates can be fit.
When installed I cut the right doors. Most of this energy will be spent on the inlet and exhaust ducking.
May 13, 2021, 12:46 PM
A-6 & B-47 OCD
FliteMetal's Avatar
Butting Up The Bulkheads
The movie former/bulkheads were far from light weight; a ply/fiberglass/ply laminate. Note the movie model creators attention to fit and finish... More hurry up and finish than attention to fit. Gotta love the symmetry. Note they "wedged" the front former to build in T/C and angle toward the exhaust outlet. There was no inlet ducting in the movie 6's.
Description: Name: 2021-05-03_113743_Former2bnonsqr.jpg
Description: Name: 2021-04-28_123832_Front2.jpg
Description:
Description: Name: 2021-04-26_051123_RearBulkheadreop.jpg
Description:
The perimeter of the originals were duplicated on 1/4" corrugation then quartered to permit overlapping to fit the sections to fuse interior top, bottom, left and right sides. On the EDF version I am doing my best to "not" have a backbone hatch. The retract door bays permit placement and access to all central interior components.
Description:
Description:
Our movie 6 does not have landing gear so the stress of "landing" was reduced to surviving "sliding". There was a wooden keel epoxied to the interior of the fuse bottom. Fuse interior is now designed with retract rails, EDF cradles, wing tube galley, inlet and exhaust duct support.
Below is an edited image of another model. Note the wing tube galley, EDF cradles, and along the outside perimeter the retract rails which run from the rear former to the EDF cradle. Thank heavens for our laser cutter...
Description:
Jun 09, 2021, 11:20 AM
A-6 & B-47 OCD
FliteMetal's Avatar
New Bulkhead/Formers
Description: Name: Working1WDim.jpg
Description: Name: WorkingTailOn1.jpg
Description:
Looks like I will be able to place the wing tube galley directly over the JetFan 110's instead of the original position for the ByroJets. The original wing did not utilize a wing tube. It used Byron's bar and slot method with one hardwood dowel near the wing leading edge. Rear bulkhead/former is 15" forward of the exhaust and new design EDF cradle is 28" forward of the exhaust.
Description:
Jun 10, 2021, 10:50 AM
3d and EDF, some scale
MustangAce17's Avatar
Very awesome project, I think I might know who has the molds but I don't associate with him
Jun 18, 2021, 06:26 AM
A-6 & B-47 OCD
FliteMetal's Avatar
Molds...
Mustang,
........................................Name: MiddleSectionPlug.JPG
Description: Name: MiddleSectionPlug2.JPG
Description:
..................................Name: MoldsWaiting.JPG
Description: Name: IMG_8665.JPG
Description: Name: 1-2-3.jpg
Description:
We created new three piece molds and enhanced the scale fidelity. The original movie sixes were void of many
details we have corrected.
.....................................Retooling of original film 1:5.5 scale (115.63” w/s) A6 Intruder includes:
.....................................(*Features not on original "Flight Of The Intruder" movie A6 Intruders)
........*3 piece easy transport fuselage. (original was 1 piece 117" long)
........*Accurate removable nose. (Access to onboard systems)
........*Accurate scale intakes. 87cm2 ea. (105.61% FSA of each 110mm EDF)
........*Laser cut framed and counter balanced flying stabs.
........*Operating leading edge slats.
........*Operating wingtip deceleron airbrakes.*option.
........*Operating spoilerons. (A6's have no ailerons).
........*Operating flaps.
........*Operating retractable scale tailhook*option.
........*Fuselage features unique to every A6 version.
........*Martin-Baker Mk-7 ejection seats.*w/cockpit option.
........*Detailed cockpit and instrument panels.*option.
..........Aluminum main and twin nose wheels.
........*Electric or air retracts w/proportional electronic brakes.*
........*Extendable~retractable aerial refueling system (KA6D).*option.
........*Articulated retarded MK81 rail mounted munitions.*option.
........*TRAM "Target Recognition And Attack Multi-sensor". *option.
I took a break for two weeks and have returned to fitting final EDF cradle and bulkheads.
Sometimes life gets in the way... New pics later today.
Jun 22, 2021, 07:01 AM
A-6 & B-47 OCD
FliteMetal's Avatar
EDF Cradle Dims
Added dim to the EDF cradle:
Description:
Jun 22, 2021, 07:41 AM
2024 EDF Jet Jam, June 6-8
Robert Belluomini's Avatar
Ed, what is you time frame on flying the first model?
Jun 27, 2021, 01:20 PM
A-6 & B-47 OCD
FliteMetal's Avatar
Robert,
Sorry it took so long to reply. I anticipate sometime between April-May '23 for first flight if everything fits as planned.
Now that many of the outsourced elements are inhouse that time frame is doable. Like Mel Brooks says..."Work, work,
work". Lots of moving parts.
Jul 15, 2021, 10:23 PM
Bizjets's Avatar
Whoa just came across this thread. If these go into production I will 100% be getting one. Good luck moving forward guys!
Jul 16, 2021, 04:58 AM
A-6 & B-47 OCD
FliteMetal's Avatar
Rollout
Biz,
..........Was targeting Santa's delivery schedule. Corralling moving parts between now and then. Life has a way of changing plans
Description:
Jul 16, 2021, 10:52 AM
Bizjets's Avatar
Originally Posted by FliteMetal
Biz,
..........Targeting Santa's delivery schedule. Corralling moving parts between now and then.
Attachment 15164849
Awesome! So i read the thread and checked out your website. Are you looking to deliver this in an ARF format? Or are we looking at a lot of building?
Keep up the good work!
Jul 16, 2021, 12:21 PM
A-6 & B-47 OCD
FliteMetal's Avatar
Sum Of The Parts
Larger assembles easier~faster:
Three piece glass fuse, bulkheads, foam wing/stab cores, aluminum wing tube, glass inlet/edf exhaust ducting, edf/wing tube cradle, retracts, clear canopy panels, flying stab bearing frame, vacuum formed components to replicate A6 version selected, leading edge slats, spoilerons, flaps, bulkheads, foam wing/stab cores, glass inlet/edf exhaust ducting, edf/turbine wing tube cradle, CNC cut surface panel sections, retracts, clear canopy panels, flying stab bearing frame, vacuum formed components to replicate A6 version selected, leading edge slats, spoilerons, and flaps. Edf/turbine cradle/wing tube galley are pre-installed in fuselage to assure proper alignment.
Description:
Jul 16, 2021, 01:32 PM
Bizjets's Avatar
Thanks for the update! Anxiously awaiting the first flights of the prototype!
Discussion Grumman A6 Intruder crowe04 Slope Soaring 19 Jan 08, 2024 03:03 PM
Build Log A6 intruder clg0816 Scale Kit/Scratch Built 502 May 19, 2021 11:01 AM
A6 Intruder EDF seen at San Diego Midwinter Electric meet 356Jim Electric Ducted Fan Jet Talk 81 Nov 21, 2004 02:43 PM
Hobbico A6 Intruder w/EDF-50 jake&mike Electric Ducted Fan Jet Talk 1 Jan 09, 2003 03:49 PM
Hobbico A6 Intruder R/C conversion HAWK3Y3 Parkflyers 3 Jul 15, 2002 04:58 PM
