Mar 03, 2021, 07:16 PM
Help!
Draining rx battery in under ten min
NEED SOME HELP I HAVE A XG8 W/2-DS368 SEVOS AND 1-DS351 HAVE A RG712BX RX ALL ARE NEW.AFTER I INSTALLED IT ALL
I TURNED EVERYTHING ON AND STARTED SETTING THE THOWS AND DUAL RATES GOT IT SET AND.THEN I WAS JUST MOVING ALL THE CONTROLLS
AND THEY STARTD GOING SLOW AND THEN STOPPED.LOOKED AT THE TX DISPLAY AND THE RX WAS DOWN TO A LITTLE ABOVE 3VOLTS.SO I CHARGED THE 6.6 700 ZIPPY LIFE BATTERY AGAIN AND STARTED GOING THRU THE CONTROLLS AGAIN AND NOTICED THE RX WAS A LITTLE WARM.NOT HOT AT ALL.AND ABOUT 8TO10 MINUTES ITS BACK DOWN TO 3VOLTS.NOTHING IS BINDING EVERYTHING WORKS REAL SMOOTH.PLEASE WHAT AM I DOING WRONG HELPHELPHELP
THANK YOU BO HAMMER
Mar 03, 2021, 08:24 PM
Slow builder
_AL_'s Avatar
Use a meter to measure your current draw & do a 1c discharge test on your battery to see if it's a battery issue or a high amp draw from your electrics.
Mar 04, 2021, 01:27 PM
Zippy6.6life
PUT THE BATTERY ON MY 4PORT HITEC CHARGER AND THE CHARGER DISPLAYS NO BATTERY DETECTED.SO NEW BATTERY MUST BE BAD.THANKS FOR YOUR SUG.BO
ALSO THE BAT STEALS READS 3.1 VOLTS ON MY HAND METER.THIS IS THE FIRST TIME USEING A LIFE PACK WAS NOT READY FOR THE FIRST ONE TO BE BAD.BUT ALOT OF GUYS USE THEM SO I ORDERED ANOTHER ONE.HOPE IT WORKS WELL AND IT WASENT ME.I REALLY DONT KNOW MUCH ABOUT BATTERYS IN GENERAL.
Mar 04, 2021, 01:43 PM
With a new life battery you should cycle it at least one time before use . If you didn't do it you might have just run it to long the first time and caused damage.
Mar 04, 2021, 02:41 PM
You should never ever allow the battery pack to be discharged below 3V (per cell). If available, set the low voltage alarm to 6.2 V.
Mar 04, 2021, 03:10 PM
Life bat 6.6
NO I DID NOT CYCLE IT JUST PLUGGED IN AND USED IT TILL THE SERVOS STARTED TO SLOW DOWN AND STOP.AND SINCE THE CHARGER DOES NOT RECOGNIZE THAT ITS PLGGED IN I ORDERED ANOTHER ONE.AND I WILL CYCLE IT.THANKS GUYS BO
Help! RX battery draining very fast. brafolife Fuel Plane Talk 25 Apr 10, 2017 02:33 PM
Discussion Judge Napolitano.How to get fired from Fox Business in under 5 mins Dave K Life, The Universe, and Politics 42 Feb 16, 2012 12:02 AM
New Lithium battery tech from Toshiba allows 80% recharge in under 1 min !!! stealth916 Batteries and Chargers 6 Mar 30, 2005 12:41 PM
