Batter run time
Hi I have an Arrma Outcast 8s. Lots off unto run. But I'm only getting 10-15 mins of run time. My batteries are Smart 5000mAh 4s 14.8v100c . What brand or power are bashers running? My charger is a Smart also. Thanks.
that is normal, if you want to increase run time, then consider reducing the KV on the motor to around 1400KV and upgrading to a 6S system, you can also reduce the throttle EPA as well, be sure to check your temps:
https://www.rcgroups.com/forums/show...nics-in-my-car Good Luck! |
![]() Seems over on Arrmaforum many of the 8s guys are running packs around 8000mah, and still don't hit half an hour run time. SMC and CHNL packs seem popular, although I have not had good luck with SMC. |
Increasing voltage while decreasing KV motor will drastically improve efficiency with lower temps and provide longer run times. I recently switched my SCT from [email protected] to [email protected] and now I can run a 20 min main with the nitros ![]() Normally SCT's are limited to 8 min mains due to 2S limit and battery capacity ![]() |
Bill, He is already running 8S - 2x4s. He'd need to go to 12s to get much of an improvement.
I know VERY little about 1/5 cars but I would definitely explore some 12S options if it were me, but only reducing the KV at the same time as increasing voltage. |
Thread Tools | |
Similar Threads | |||||
Discussion | How to charge 1s lipo batter at a time | wark64 | Batteries and Chargers | 3 | Sep 07, 2017 08:55 PM |
Discussion | Poor run times on lipo batteries. | Tomsmith1992 | Electric Power Cars | 18 | Oct 19, 2015 02:18 PM |
Discussion | Air Force times runs Veterans ad urging drone operators not to fly missions | treehog | Life, The Universe, and Politics | 0 | Sep 20, 2015 10:53 AM |
14 cell = longer run time Logo 10? Or just more power, same run time? | Astro30 | Electric Heli Talk | 1 | Aug 07, 2003 08:44 PM |
