Mar 03, 2021, 03:27 AM
Tony Audsley Retired Locksmith
Lockey's Avatar
Build Log
de Havilland Vampire T55
Hi Guys, I've had this on on the drawing board as a 3D printable for a long time but kept pushing to to the back because I thought it would be too heavy in 3D print ..
BUT .. now we have LW-PLA, its time I put it back on the drawing board
I will be doing it as both pusher and EDF and I will be using my "slip-lock" joining system on the fuselage
I've done a bit more work on it today and this is what I have so far ..
Specs:
3 channel .. Throttle, Ailerons and Elevator
1200 mm wing span
1000 mm Long
70mm EDF
Estimated weight 1400 - 1500 grams
Slide on grass take off and landing (well the EDF will hopefully be SOG)
Deflections
Ailerons: Up = 13mm .. Down = 10mm
Stabilizer: Up and Down = 15mm
Old wing ... C of G = 67 mm from leading edge (see pic)
NEW WING .. C of G = 65 mm from leading edge (see pic)
I have widened the wing tips a little and included a couple of degrees washout to hopefully make it fly a little nicer
Look forward to your comments
I would suggest that you try the G-code files for printing
If you would rather use the STL files and slice yourself, here are the settings I use ..
PLA Parts
These are the settings I use .. doesn't have to be exact
Nose is best done fine .. maybe layer height 0.1 and 3 top layers 2 wall with 6 to 8 % infill ..
Formers .. layer height 2 or 2.5 .. 2 wall, 2 bottom and 3 top layers with about 12% infill
Boom .. layer height 2 or 2.5 .. 1 and 2 .. about 12 % infill, 2 bottom, 3 top layers
Landing Gear insert .. layer height 2 or 2.5 ... 2 bottom and 3 top .. infill maybe 20% or higher
Small parts (Hooks and bits) 100% infill
LW-PLA Parts
Parts with "bottom layers"
Fuz 1 = 3 bottom layers
Wing 1 .. LH and RH = 3 bottom layers
Fuz 1 Hatch = 3 bottom layers
Aileron 1 (with control horn) .. LH and RH = 6 bottom layers
Aileron 2 .. LH and RH = 3 bottom layers
Elevator 1 (with control horn) .. LH and RH = 6 bottom layers
Elevator 2 .. LH and RH = 3 bottom layers
H-Stab LH and RH .. 3 bottom layers
H-Stab Tip LH and RH .. 3 bottom layers
All the rest of the LW-PLA parts are open (no bottom layers)
Hardware I use:
EDF: 760mm FMS or Freewing
ESC: 60 to 80 amp
Servos: 9 gram
Spars: 4.2mm ID arrow shafts
Filament: LW-PLA for fuselage and wings ..
Filament: PLA+ for other parts
Pushrods: 1.2 or 1.5 mm piano wire
Lockey
Mar 03, 2021, 05:28 AM
I'm new to 3d printing, but I have my eye on getting the Prusa i3 MK3S. Will your Vampire print on that machine?
Mar 03, 2021, 05:54 AM
Jockadopolus's Avatar
Tony I'm in and see what arrived yesterday.
Joe
Mar 03, 2021, 06:21 AM
Lockey's Avatar
Sure will, that's my machine, and I also have a Sidewinder
Joe, I just got a 4.5 kg roll
Lockey
Mar 03, 2021, 07:09 AM
When cows fly!
Nice! Love the vampire!
Mar 03, 2021, 02:52 PM
Lockey, would you consider incorporating finger holds for hand launching? I'm not too sold on SOG, thinking that it doesn't have yaw authority.
Mar 03, 2021, 04:48 PM
Retired CAD guy
birdofplay's Avatar
I really like popcorn
Mar 03, 2021, 05:34 PM
Don't leave it Stock
mrfliboy's Avatar
May I, raises ✋
All time favorite, just finished testing lw.
Great design
Mar 03, 2021, 06:48 PM
Lockey's Avatar
Will certainly have a look at that Jay, with my all foam version I hand launched it under hand (see video) of course with the pusher prop version it has to be hand launched .. but I will see how I can add finger holds to the under side
Incidentally .. strange as it may seem, it is possible to steer on the ground with ailerons
mrfliboy .. I will post the settings I use in Cura for "spiral" printing of LW-PLA .. I only ever design and print LW-PLA in spiral mode and I think I have found the "sweet spot" .. at least for my models
Lockey
EDF Vampire Blowout and Vampire Pusher 2nd flight (4 min 55 sec)
Mar 03, 2021, 07:05 PM
Lockey's Avatar
These are my Cura setting when I print my parts in spiral mode
These setting should give about a 0.75 - 0.8 (give or take) wall thickness when printed, I find this to be the sweet spot for strength and weight .. I have printed with a lighter wall and although it is lighter I don't like the feel of the strength .. just my opinion of course
Lockey
Here are the tests I did:
I hope these tests will help some of you guys using (or intending using) LW-PLA .. these are for Spiral Mode "continuous" single wall for optimum strength and weight .. using Cura Slicer
The settings I have been using for LW-PLA up to now are .. Line width (wall thickness) 0.35 .. Layer height 0.2 .. Flow Rate Compensation Factor 50% .. Speed 70mm/sec (now use 100) .. temp 240 .. bed temp 65 ... spiral mode "continuous" single wall
I did 5 tests and these are my results
1. Line width (wall thickness) 0.35 .. Layer height 0.2 .. Flow Rate Compensation Factor 50% .. Speed 70mm/sec .. temp 240 = Finished wall thickness 0.81 .. Print speed 17 minutes
2. Line width (wall thickness) 0.33 .. Layer height 0.25 .. Flow Rate Compensation Factor 50% .. Speed 70mm/sec .. temp 240 = Finished wall thickness 0.81 .. Print speed 14 minutes
3. Line width (wall thickness) 0.33 .. Layer height 0.3 .. Flow Rate Compensation Factor 50% .. Speed 70mm/sec .. temp 240 = Finished wall thickness 0.85 .. Print speed 12 minutes
4. Line width (wall thickness) 0.30 .. Layer height 0.3 .. Flow Rate Compensation Factor 50% .. Speed 70mm/sec .. temp 240 = Finished wall thickness 0.80 .. Print speed 12 minutes
5. Line width (wall thickness) 0.25 .. Layer height 0.35 .. Flow Rate Compensation Factor 50% .. Speed 70mm/sec .. temp 240 = Finished wall thickness 0.71 .. Print speed 10 minutes
The first 3 were very similar to feel the strength of the wall on both the flat and the curved surface .. the 4th one started to feel a little flimsier and the 5th one felt too flimsy
I wasn't possible to get an accurate weight difference as the samples were too small
My conclusion is to go with number 2 .. possible small saving on weight .. faster print .. and a slight saving on filament
Number 5 would be good for small lightweight and indoor models
Lockey
Mar 03, 2021, 09:02 PM
Retired CAD guy
birdofplay's Avatar
Bravo!
You cant expect a high roll rate without any prop blast over those surfaces.
That was a high-pitched noisy little edf in your Vampire.
Proved to be a great little fun flying plane. cudos
Here is my latest Foamy
38" Rafale foamy (5 min 1 sec)
Mar 03, 2021, 09:27 PM
Sign me up. Printing the BD-5 was great. Still waiting for the weather to work itself out so time to print this!
Mar 03, 2021, 10:12 PM
Lockey, I checked out your all-foam Vampire build thread, and it is quite a bit smaller and lighter than this 3d printed version. To tell you the truth, I would be pretty freaked out to try to underhand-launch this big one. Maybe not the most rational thinking, but I lost my most important plane from an underhand launch back when I wasn't very good at hand launching, and ever since then, I've concentrated on overhand launches. In any case, there might be enough meat under the wing to grip it solidly, since it is mostly a mid-wing design. Below is what I had in mind for finger grips, although the Viper is a low wing plane.
Mar 03, 2021, 11:59 PM
OK, I figured it out. Lockey, you won't have to change anything. I remember now how it was handled on a similar mid-wing design. They glued strips of sandpaper on either side of the fuselage right under the wing just behind the CG. You can paint the sandpaper, and it will still retain the grittiness that you need to grip the plane.
Mar 04, 2021, 12:48 AM
The Vampire is looking great
Build Log de Havilland DH.100 Vampire Mareczek Electric Warbirds 7 May 02, 2021 09:37 AM
Help! Flying Scale Models April 1998 De Havilland Vampire Plan 41 onewonders Scale Kit/Scratch Built 7 Oct 02, 2018 10:17 PM
Build Log de Havilland Vampire Lockey Foamies (Scratchbuilt) 109 Oct 24, 2017 04:31 PM
Video De Havilland 100 Vampire MK2 70mm EDF jet crash robertmax Foamy EDFs 6 Mar 17, 2017 02:08 AM
Video De Havilland 100 Vampire MK2 70mm EDF jet robertmax Foamy EDFs 0 Feb 28, 2017 12:45 PM
