This thread is privately moderated by TBY, who may elect to delete unwanted replies.
Mar 02, 2021, 07:50 AM
TBY
TBY
Mini-Review
Volantex Phoenix V2 2000mm Wingspan EPO
Hi
A mini review and some small upgrades on the Volantex Phoenix V2 2000mm Wingspan EPO glider.
My Shopping experience:
Bought the first one on Banggood. It went missing somewhere in China 😊
Banggood sent me a second one. Arrived broken☹
The third one I have ordered from https://www.der-schweighofer.at/. It’s under the name “MODSTER PHOENIX V2 2000MM” (same plane) and they had a big discount. This time, it has arrived in mint condition.
What I like:
Plug-in system for the wings on the fuselage using a snap lock (see pic.).
Flap servo is “inverted” (see pic.). You can use two standard servos for flaps with Y connection.
A lot of place in the front fuselage. Got an elevated “balcony” for the receiver (see pic.).
Plastic fuselage.
What I don’t like:
Very low-grade servos. 3 broke after few flights without any hard landings.
A bit heavy and needs about 15gr in the tail for a 3S 2200mah.
Spinner looks a bit flimsy.
Flight experience:
It flies a bit faster than Multiplex EasyGlider.
I do not think that it's very good with thermal soaring. Did not fly a lot so I am not sure about it. Please comment on this if you have other experience.
Some ideas:
Address the servos issue!
If you choose to stay with the original servos: Check servos carefully before each takeoff and
Install servo covers.
There is an opening in the rear end of the body that enables you to add a balancing weight inside the body.
I have added a tube inside the body where the wing rods are (see pic.). That prevents the rods from contacting the servo cables each time I insert them.
I have changed to Aero-naut propeller.
Bottom line, for the right price it is a very nice value for money PNP glider…
Apr 09, 2021, 01:08 PM
FPV'r
ror1's Avatar
it thermal soars very well...just make sure CG is correct.
No weight has been added to tail.
Never take wing off..
I find it lighter than my phoenix 2000 V1 and a better soarer because it is lighter.
where can I get the wing rods for the 2000 V2?
thanks
Apr 11, 2021, 03:10 AM
TBY
TBY
Hi
Best if you buy it from schweighofer.
This looks like it:
https://www.der-schweighofer.com/MOD...stange-a283271
Send them an email and ask.
If they do not have it, I looked it up. It's a 0.3" (7.8mm) hollow aluminum rod (21cm and 47cm)
Not sure 8mm will fit in.
Check online.
Good luck with your search
Apr 11, 2021, 11:05 AM
FPV'r
ror1's Avatar
Originally Posted by TBY
Hi
This looks like it:
Check online.
thanks alot..
might cost the earth to ship to Canada but thanks anyway.
this is the 1st time i have seen it online...you would think Banggood would carry it but i guess they want you to buy whole plane.
Apr 13, 2021, 11:10 PM
FPV'r
ror1's Avatar
Hi
This looks like it:
Check online.
sorry found a cheaper place:
Support EXHOBBY <[email protected]>
Just email them and they will order for you...it is not shown online.
thanks again.
Apr 14, 2021, 01:45 AM
TBY
TBY
Good news
For me, ordering a whole plane to Israel - Schweighofer was safer, faster, and even cheaper than China's options. You are right, ordering a small part from them is not economic.
Safe flying
May 09, 2021, 09:22 PM
FPV'r
ror1's Avatar
New V2 production run
Comes with those cheap push on control horns instead of the 4 screws type.
Come on !!! Really...
New Product Volantex TrainStar Epoch 747-6 V2 1100mm Wingspan EPO Trainer Aircraft RC Airplane KI Merch Banggood.com 1 Dec 15, 2020 04:40 AM
Discussion Volantex PhoenixS 742-7 4 Channel 1600mm Wingspan EPO RC Airplane with Streamline Merch Banggood.com 20 Oct 21, 2019 11:28 AM
New Product Volantexrc Volantex 759-3 Phoenix 2400 2400mm Wingspan EPO RC Glider Airplane PNP Merch Banggood.com 41 Mar 26, 2019 06:37 PM
