This thread is privately moderated by TBY, who may elect to delete unwanted replies.
Mar 01, 2021, 05:38 AM
TBY
TBY
Mini-HowTo
FRSKY Archer SR8 PRO External Voltage measurement
Hi
FRSKY Archer SR8 PRO has an External Voltage measurement via AIN2. The manual describes this as:
Voltage Measurement Range via AIN2 (External device): 0-36V (Battery Voltage Division Ratio: 1:10).
No other explanations for this feature.
I’ll write down my experience with this option:
The AI2, green cable, will go to the external battery +
The -, black cable, will go to the external battery -
Be aware that this receiver accepts 0-36V. It has its own voltage divider inside. Other receivers might accept lower voltage!!!!
The other issue is the Voltage Division Ratio. The manual declares 1:10 ratio. Setting this sensor up with 1:10 ratio gave me unreasonable outcome.
I have used two batteries (3s and 4s) and a multimeter and started to “play” with the values. For this receiver, the best values were a Ratio of 35 and an offset of 0.57V. Got a good voltage reading for the two measurement points that I used.
My colleague, Lior Zahavi - i3dm, suggested that the difference (ratio) is because I’m using OpenTX.
Hope that this small “how to” helps.
Please feel free to add your division ratio values and/or comment on this issue.
TNX
Help! FrSky SR8 Pro not binding to Taranis X9D+ 2019 jacksonmarkow FrSky 2 Mar 01, 2021 10:55 PM
New Product FrSky 2.4GHz XJT Lite External Transmitter Module for FrSky X Lite S/Pro X9 Lite Tran alex_nikiforov Banggood.com 0 Aug 16, 2019 11:39 PM
Question Which External BEC Voltage to Select 5.0v, 5.5v, 6.0v ? KenS999 Power Systems 4 Apr 01, 2016 04:45 PM
Discussion Graupner circuit voltage measurement pragamichele Graupner – Control Hobbies 2 Jan 17, 2016 05:25 PM
Discussion FRSky D4FR, a mod to monitor an external voltage Malx Radios 8 Mar 30, 2012 10:45 PM
