Help!
need help with drone tyro 119
i do not know where to post help info so if i am in the wrong place your welcome to move me lol. i did look
i need help with a tyro 119 i have a Hobby King 2.4Ghz 4Ch Tx V2. the Receiver is a 6 ch . i can get the Receiver to bind with my controler but i can not get none of the controls to work. nothing happens i first bridge the sbus then switched to ppm on the board. i tryed looking at the beta flight and firmware to newest setup 4.1.1 i really need help here. my main problem atm on this learning curve is knowing what Receiver is what. like is it ibus sbus ppm and so on. i can not find info on this cheap Receiver other then it my be flyski setup.......... all the videos i seen online only show people installing high end Receiver. or another brand. but no info on a hobbyking 6ch Receiver or other types like it. |
You need a radio with at least 6 channels. 4 channels for control, 1 channel for arm/disarm and one for flying-mode.
ok thank you. going to order a 10 channel i seen. flysky fs-tm10. hope this one well work. and is flying mode a switch that needs to be set in the beta flight. i was reading up on beta flight last night. about the arm button on aux 1 but did not seen flying mode
A 10 channel radio will be perfect.
The flight modes are set in Betaflight and assigned to a switch on your radio. It's how you switch from self level flight to full manual flight etc. Note: you don't need to set up a flight mode switch on your radio if you don't want one as you can just set it in Betaflight to stay permanently in self level mode or manual mode. |
Thread Tools | |
Similar Threads | |||||
Discussion | Tyro 119/129 flight controller pinout problem | VooDooCC | Multirotor Drone Talk | 1 | Feb 02, 2021 11:19 AM |
Discussion | Tyro 119 | cgbillb | FPV Talk | 3 | Nov 18, 2020 07:53 PM |
Question | Build Log for a Tyro 119 Drone | cgbillb | The Builders Workshop | 1 | Nov 15, 2020 04:58 PM |
Question | Tyro 119 | cgbillb | Mini Multirotor Drones | 0 | Nov 14, 2020 03:30 PM |
Discussion | Need help with Park 480 power system for Tyro 150 | RC Floater | Power Systems | 4 | Apr 06, 2013 05:37 PM |
