Thread Tools |
This thread is privately moderated by scruffy1, who may elect to delete unwanted replies. |
Gallery
trottel
finally got my version of thomas b.'s little stunt machine together; the original thread is here :
https://www.rcgroups.com/forums/show...hine-free-plan it employs a kfm4 airfoil in depron, as is the rest of the plane, barring plywood motor mount and undercarriage former for those that haven't encountered them, the kline-fogelman family of airfoils are very simple to build and perform admirably at the sizes employed in model aircraft https://www.flitetest.com/articles/k...ic-explanation the step is a bit f..ugly, but in the air that's impossible to notice if you like the idea, the cute "jupiter shrimp" (also a thomas b. design) might tickle your fancy https://www.rcgroups.com/forums/show...0#post39845079 i modified the details of the trottel's fuselage section (a touch more taper for aesthetics, the motor has a cowl of sorts, and carbon spar nose surrounds to save it from gravel rash and prop bite), and added dual aileron servos to allow some embellishments with the controls (see later) i also ironed 80 micron laminating plastic on the wing leading sections back to the step; a fold at the leading edge makes the entry sharp and consistent along the span, and strengthens the resistance to nicks from minor impacts - this is the same stuff used for document lamination, and i have since picked up a stash of 75 micron stuff that's as yet untested the red stripes are 45 micron wing tape from hobbyking (old stock i have had for ages), while the wing tip plates and rudder are fluoro monokote that is hard to miss in the air - same as my binary dlg fin hinges are blenderm top and bottom, which was applied over the decorations so the deep V in the hinge wouldn't be inclined to disengage all up weight is 187 grams dry components :
as yet unflown; i need to hose down the throws with rate switches, and the ultimate goal is to also program flaperons and snap flaps to both up performance, and also get some experience at programming the x9d+ will post some flight video eventually i expect, but it's too hot here currently for my delicate sensibilities ImagesView all Images in thread
Mine, just completed. Ready for maiden next week. I followed your suggestion for motor/prop/ESC/battery so we'll see how that turns out. 189g AUW.
Thread Tools | |
Similar Threads | |||||
Build Log | The Trottel - a simple and versatile aerobatic/3D machine, free plan | Thomas B. | Foamies (Scratchbuilt) | 517 | Sep 12, 2023 11:43 AM |
Discussion | Trottel not 100% on hobbyking k2.1 fc | mattiashem | Multirotor Drone Electronics | 1 | Mar 28, 2014 02:38 PM |
