Jun 16, 2006, 09:35 AM
Hello from Germany (this is where the Soccer World Championship 2006 takes place )
here are some pics of my MF
maidenflight was on Wednesday 14-06-2006
greetings
FlyingDoc
Jun 16, 2006, 10:06 AM
semper ventosus
weather_man's Avatar
Quick question,
What do you guys think about this motor for the MF?
http://www.bphobbies.com/view.asp?id...27&pid=W392031
Jun 16, 2006, 10:21 AM
FlyingDoc.. How did you like the AXI and what kind of flying time did you have with What pcak? MF looks great!
Jun 16, 2006, 10:23 AM
Andy W's Avatar
Originally Posted by weather_man
Quick question,
Too big and heavy..
..a
Jun 16, 2006, 10:40 AM
the first flight was only a short one - about 6 min and just flying around - only two verticals (and they were fantastic )
it's the Axi 2808/24 with an APC 10 x 5 E
XPower LiPo from Dualsky.com 1700 mAh 3s (120 gr)
total weight of the MF is 690 gr (= 24,34 oz avdp)
the charging only got 532 mA in the LiPo - so the total flight time will be above 10 min i think...
first time I used this brand of LiPo...
but they seem to do their job....
so long
FlyingDoc
Jun 18, 2006, 04:07 PM
Hi,
today, after four flights with wing in back position I changed to forward position...
well, now I know why u guys have the LiPos in the frontposition...
I had to bring my 120gr-LiPo into the front behind the firewall, where you sure all have yours too...
even a little noseheavy (CG still at about 80mm from leading edge) I now have a completely different flyer - wow, so easy to handle - so easy to hover...
now that's the Mini-Funtana that i wanted to have when I ordered it...
thanks e-flite for the forward wingposition ;-) never will go back again....
so long
FlyingDoc
Jun 18, 2006, 04:21 PM
FLY PEMBREY (PFC)
milky2971's Avatar
HI All
Ive been flying my MF for about 11 months now and have always found it really docile!!!
its alot better now Ive fitted a Cobri and got the gearing right Im flying on a 11x4.7 Sf APC instead of a stock 12x6 on a modified himax box (it kept eating spurs) and now locks superbly into hover with great pull out
I tried moving the wing to the forward posistion and to be honest didnt notice that much of a difference other than the elevator appearing more sensitive and it doesnt seem to glide as well as before
Ive read elsewhere that this would help with the rudder response....but feel its identical
the main reason for this post is how can I improve the rudder as this is the only downside to this model for me
cheers
Trev
Jun 18, 2006, 06:04 PM
Carl Petersen's Avatar
greetings
FlyingDoc
Nice job. Where can we get the spinner that you used?
Jun 18, 2006, 08:04 PM
Jimmy Hoffa's Avatar
I use a 3mm Depron extension taped to the rudder with clear packing tape. Works well.
Phillip
Jun 18, 2006, 10:37 PM
a320jockey's Avatar
Large Spinners
My yellow/blue/red Mini Funtana has a 1 1/2 inch plastic spinner from Dubro.
Best regards,
Carlos A. Cordova
QUITO - ECUADOR
Jun 19, 2006, 06:05 AM
the Spinner is from AERONAUT
I got it here: http://www.kd-modelltechnik.de
search for this : AE7253-30-31-32
It has a central M2-screw to be fixed.
FlyingDoc
Jun 19, 2006, 07:17 AM
Closed Account
The Aeronaut also needs a "Spannkonus" or collet adapter for the M2 screw to attach to and to hold the prop on the shaft. Click on "Mitnehmer" under "Luftschrauben" and scroll down to the Spannkonus that works for you. No, I don't speak/read German but I slept at a Holiday Inn once.
Jun 19, 2006, 07:47 AM
Thanks FlyingDoc and Ron. I'll check into an inn at once.
Jun 19, 2006, 08:46 AM
well, it depends...
I tapped (is that the word?) a M2 into the hub of the "Radial Mount Set" and so the spinner can be fixed to that part...
another way would be a "Spannkonus" with a winding in the hub... that's true... ;-)
Jun 19, 2006, 11:25 AM
Closed Account
Actually, Hobby Lobby has something quite similar:
http://www.hobby-lobby.com/propadap.htm
I seem to remember some Aeronaut (???) spinners for non folding props in their paper catalog - and Esprit Model has some too:
http://www.espritmodel.com/ Once again, click and scroll.
Mini Funtana - Quick Build...and Fly Part #4 JWarren 3D Flying 510 Jun 16, 2005 02:56 PM
Rant My Mini Funtana is toast thanks to stupid berg 5 Alkaline Vendor Talk 42 May 02, 2005 08:28 PM
Mini Funtana - Quick Build...and Fly Part 3 SchiessCo 3D Flying 491 Apr 11, 2005 10:32 PM
Mini Funtana - Quick Build Part 2 Martin Hunter 3D Flying 725 Feb 19, 2005 12:11 PM
Mini Funtana - Quick Build Harley 3D Flying 650 Jan 04, 2005 07:56 PM
