Mar 11, 2021, 03:00 PM
Originally Posted by powercroco
As I just said, some of them are still available - so no problems from this side.
but i don't know, how to place the controller and the batteries for the "normal" 400+ Amps to supply it.
may be the first elysium with >200g/dm²
Why not,
Fuselage is suitable for 400A esc
Mar 11, 2021, 03:26 PM
Closed Account
and now put in the needed batteries too!
Mar 12, 2021, 11:23 AM
All you must know about forcing 500+ km/h
Mar 12, 2021, 11:25 AM
Power leads, and servo...
Mar 12, 2021, 01:25 PM
The Prop is Where its At!
blitzu's Avatar
I like the 'neatness' of your work Dzhamel-looks good!
Good to see your still around Ralph
Mar 12, 2021, 01:39 PM
Thank you for positive mark!))
Ralph always help me if the project close to crazy😅😅
Mar 13, 2021, 12:57 PM
Mar 13, 2021, 01:21 PM
Closed Account
Do you really need the full lenght in all cables?
Btw. I use different colours in the interconnections between the packs to prevent misconnecting them.
red and black to esc;
green for interconnection1 and yellow for interconnection2 (example)
found also better to use coloured silikon tubes instead of shrinking tube. It is better heat resistant.
https://www.ebay.de/itm/Farbige-Sili...ed4c%7Ciid%3A9
Mar 13, 2021, 01:35 PM
Yes,
i use colored heat shrinks too, after one time i mistaken with it😅😅
I will adjust it during the first connection inside fuselage, for know which the better connection between packs will be.
Mar 14, 2021, 05:41 AM
Rod endings for flaps,
картинки для перевода
Mar 14, 2021, 05:45 AM
I need the new spinner (
Old one turned out to be broken after being hit.
Mar 23, 2021, 11:31 AM
Elysium wing servos test (2 min 2 sec)
Mar 23, 2021, 12:32 PM
One Idiot is plenty...
Dbox's Avatar
$1800 plane has no wing wipers !!!
Wow! Wow! Wow!
Yuri
Apr 17, 2021, 10:48 AM
Not interesting, but maiden flight.
Elysium maiden flight (3 min 21 sec)
Apr 17, 2021, 02:43 PM
Free Flight rubber flyer
jwfinn's Avatar
Maybe hard to see in the video but still it sounded magnificent!!!
New Product Hjk elysium Pryonic High Performance 7 Mar 03, 2021 11:51 AM
Build Log HJK BIG MONSTER + PowerCroco 5050 + APD HV Pro 400A Dzhamal High Performance 179 Feb 04, 2021 06:21 AM
Discussion Scale laser 200/sentilon hv 100a/fp 3700mah 12s would anyone recommend an outrunner? margaret.roberts Power Systems 0 Apr 10, 2008 06:00 PM
Discussion Electric Platform with 200 gm payload?? ashvani Aerial Photography 17 Jan 24, 2007 09:40 AM
