Mar 21, 2021, 06:09 PM
Fourdan's Avatar
Billzilla
Finally have you selected/bought your monsters ?
Louis
Latest blog entry: Scorpion Calc
Mar 22, 2021, 12:38 AM
My cat moderates better
BillzillaAus's Avatar
Nope.
Apr 19, 2021, 05:31 PM
Thats right, ...
... wait for the hommies to whiegh in to commit the monitary fundage! Laramie.
May 18, 2021, 12:12 AM
Skylar's Avatar
Possibly the most important question when designing a motor from scratch is: what will the Kv be? Things like stator length vs diameter ratio, number of slots, magnets and turns all play a role in yielding a very specific Kv. So the question is, is it possible to determine the Kv before the motor is built and wound?
One method is using eMetor to calculate Kv and other parameters of just about any size motor. You're welcome to try it, but I found it too daunting and gave up.
I decided to look for trends in existing motors, i.e. how Kv changes with e.g. stator size and I started making a few "rules of thumb" based on my observations. When I put these "relationships" into an Excel spreadsheet and tested it, I was surprised by how accurately I could predict Kv for just about any size motor, and how many turns were needed for a target Kv. Granted, it may not be very scientific, but it works for me. For example, I used the spreadsheet to design a 10kW paraglider motor and after building it, which included having the stator laminations laser cut, the predicted Kv was just about spot on!
So the answer to your original question is, yes, there are rules of thumb for designing and building motors. I have figured out some rules that work for me.
If you really want to go the route of designing and building your own motors, here is a head start:
Doubling the stator length will halve the Kv.
Increasing the stator diameter by 33% will halve the Kv.... (e.g. 30mm vs 40mm dia)
May 18, 2021, 02:22 AM
Thanks for that, good to know.
May 18, 2021, 01:12 PM
homo ludens modellisticus
Ron van Sommeren's Avatar
Originally Posted by BillzillaAus
I need something about 80 kW ...
For motors in RC we use a conservative rule of thumb for continuous power: 4watt per gram motormass.
But I very much doubt if that rule is applicable for your motor.
The power will be lower because surface-to-volume ratio is lower. A mouse can shed more heat than an elephant.
Originally Posted by Skylar
... Doubling the stator length will halve the Kv. ...
That rule is the result of one-on-one relationship hard physics
Voltage induced in a wind is proportional to surface of that wind.
Doubling stator length doubles induced voltage, therefore rpm/voltage halves.
Vriendelijke groeten en wees voorzichtig, Ron
• Without a watt-meter you're in the dark ... until something starts to glow •
E-flight calculatorswatt-metersdiy motor tips&tricksCumulus MFC
Discussion Rules of Thumb for Profile Funfly Designs imacflier 3D / Fun Fly Fuel Planes 3 Apr 27, 2017 10:31 AM
Rules of Thumb for Aircraft Design - Angles of Incidence, etc. AZ_Astro Beginner Training Area (Aircraft-Electric) 12 Feb 18, 2016 07:30 PM
Question Flap design rule of thumb for sailplanes Ricardo RW Modeling Science 4 Sep 05, 2007 02:55 AM
Question Sources for design rules of thumb. david_r2ese Modeling Science 7 Feb 04, 2007 12:42 AM
Is there a rule of thumb for designing planes Dezynco Fuel Plane Talk 2 Apr 26, 2004 03:04 PM
