Feb 09, 2021, 04:19 AM
servos
Hi all what is the differences between
Hitec HS-425BB Deluxe Ball Bearing Standard Servo ?
and
Hitec HS-422 Standard Servo Direct Drive, Dual Oilite Bearings?
looking to put theses in a Phoenix Model Zero RC Plane, .46 Size ARF
Feb 09, 2021, 12:17 PM
Bitingwolf's Avatar
and
The only difference seems to that the 425 has Ball bearings(Better, less wear) vs the 422 with Oilite Bearings(Bushings). It looks like the price difference is not that big so i would go with the Hitec HS-425BB Deluxe Ball Bearing Standard Servo.
Hope that helps and feel free to ask additional Questions.
Feb 10, 2021, 12:38 AM
Thanks for your help. That was the ones i was leaning towards.
Feb 10, 2021, 02:18 AM
Atomic Skull's Avatar
My brother has a metal lathe that was made in the 1930's which uses oilite bearings and they are still good. Oilite bearings can be more precise than ball bearings and they handle high loads better. Plain bearings are in no way "worse" than rolling element bearings which is better all depends on the application.
Feb 11, 2021, 09:22 AM
Mark LSF # 3792
Yes, oilite bearings can be better for load carrying and impact loads. However, they need to remain clean of debris and be properly lubricated to do so. The ball bearings used in servos have seals that help to keep debris out of the races.
Question Servo (Turnigy Servos) jobinseattle Beginner Training Area (Aircraft-Electric) 7 Jan 17, 2016 03:58 PM
Discussion airplane servos for steering servos? ZipSnipe Car Talk 8 Jan 10, 2016 11:29 PM
Discussion Servo recommendation for digital 9g servo? cjbucher Servos 17 Nov 03, 2015 10:24 AM
Discussion Do I need to do a servo calibration after replacing my servo? Noobie1 Micro Helis 4 Oct 14, 2015 09:19 AM
Question Servo arm/output shaft slop in modelle-Expert (Mexx) 85 BB MG servo Squinton Servos 0 Oct 03, 2015 09:31 AM
