Jan 31, 2021, 08:50 AM
AMA# SIMAGES
simages's Avatar
Originally Posted by beazld
Being your first CL plane be sure that the elevator hinges are loosy-goosy. This isn’t an RC job. Your elevator should flop down with no pressure on the bellcrank. Like to use old time fabric hinges or pin type hinges in my CL control surfaces. I find CA hinges too stiff for CL planes. Just my $0.02 but others may chime in.
Really appreciate the feedback as I'm lacking the C/L experience....
Jan 31, 2021, 01:01 PM
AMA# SIMAGES
simages's Avatar
Wing becoming solid.....
Working on the trailing edge by gluing the ribs to the 1/16" x 1-1/4" x 40" balsa sheet, then added 1/8" x 5/16" balsa webbing to the TE. Will help strengthen the wing when "grabbing" it in and out of the circle.....
Before gluing the top TE balsa sheet, I hit all the joints with Medium CA, I'll do the same with the rest of the wing after finishing up the leading edge.
Also, added that extra R2 rib to the outboard side.
Jan 31, 2021, 03:19 PM
Eugene, Oregon. USA
floydcarter's Avatar
Another typical Ringmaster build error. You do not need more than 1" of elevator up and down deflection.
Jan 31, 2021, 03:25 PM
AMA# SIMAGES
simages's Avatar
Thanks, I hear the Ringmaster can be sensitive....
Jan 31, 2021, 06:12 PM
AMA# SIMAGES
simages's Avatar
Finished the trailing edge with the two triangle pieces.
Installed the 1/2" x 1/2" hard wood for the leading edge as well as the remaining R1B and R1D center half ribs plus the braces W1 and W2.
Feb 01, 2021, 05:27 AM
gene6029's Avatar
Your assembly looks clean and neat. You are doing a good job. What size bell crank are you planning on using? Does the kit provide a weight box for the outboard wing?.......Gene
Feb 01, 2021, 11:01 AM
AMA# SIMAGES
simages's Avatar
The kit doesn't provide a weight box for the outboard wing however; the kit includes hardware so, I have a 3 - 5/16" bellcrank.
Feb 01, 2021, 12:22 PM
gene6029's Avatar
Thats the size i have in mine (3"). I installed a weight box and adjustable leadouts too....Gene
Feb 01, 2021, 12:33 PM
AMA# SIMAGES
simages's Avatar
Four others bought this kit and I'm getting feedback from one. He just did a mock up to establish weight needed for the CG.
He has 1 oz weight on the outboard wing back at the trailing edge.
Added 4 oz weight at the center rib back at the trailing edge.
He anticipates 2 oz lead on each side of the fuse back at the trailing edge, hidden by the 1/16 planking in the center of the wing.
Then the 2200 battery was pushed back in the bird house to help with the CG test.
He noted to beef up the planking to hold the lead.
I appreciate the feedback!!
Feb 01, 2021, 01:20 PM
Programed for Control Line
It will be a real porker if you add that much lead. I’d suggest not guessing at the CG and wait until your all finished. If you need tail weight start by adding a tail wheel. If you still need more then a little bit of lead in the fuse at the very back under the horizontal stab. Never heard of anyone adding weight at the wing trailing edge before.
Paul
Feb 01, 2021, 04:00 PM
BWA
BWA
Absolutely no need for that extra weight near the fuselage, the only extra weight you need is in the outer wing tip.......to balance the weight of the lines.....
I believe there is enough forward/backward movement in the battery compartment to use it for nose/tail balance.......
I would really like to know his thinking on that extra weight, in 60 years of building control line planes, I have never heard of anybody doing that......
HaHa, looks like Paul and I were typing at the same time.....
Feb 01, 2021, 04:10 PM
AMA# SIMAGES
simages's Avatar
Although new to it all building and flying C/L. After years of flying, could it be a personal preference for a level take off and landing......
Feb 01, 2021, 05:18 PM
AMA# SIMAGES
simages's Avatar
Added a bit more to the Bellcrank plate and using birch instead, as well as 1/4"x1/4" hardwood supports. This way the glued plate will grab the forward ply spar, R2 and R1 ribs......
Feb 01, 2021, 06:05 PM
gene6029's Avatar
As others have allready said, weight in the outermost wing tip,( possibly 3/4oz), and the only other place you might need weight would be at the extreme tail end of the fuse to get your CG correct. The lighter you can keep your Ringmaster, the better it will fly. ....Gene
Feb 01, 2021, 06:14 PM
AMA# SIMAGES
simages's Avatar
That's what I was thinking, the wing tip with 1/2 to 3/4oz and the tail if needed and I like the tail wheel idea, if weight is needed. Also; battery box should help as well.
Discussion Top Model Albatros Classic Sport build and discussion gquiring Electric Sailplanes 35 May 06, 2019 12:43 PM
Discussion Top Model Albatros Classic and Sport chicopee5 Electric Sailplanes 2 Sep 01, 2017 05:45 PM
Help! Ringmaster - How much rudder offset 42 inch wing Hoot Control Line 9 Jul 25, 2016 04:33 PM
Discussion It's Classic, it's RC, and it flew Stunt... AndyKunz Classic Pattern Flying 1 May 31, 2016 01:40 PM
